rachwalj's Avatar
How did YOU fix your electrical problem
Seeing as SO many of us encounter electrical problems of ALL sorts and after reading many of the threads, very few actully list the "fix".
BESIDES cleaning the grounds, please post what you did to FIX the problem.
SOLD 944 n/a. Searching for next endeavor...
Old 07-16-2004, 06:31 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
the driver's side switch for the passenger window was somehow causing my battery to drain... so i disconnected the switch. Someday i'll figure out what the real problem was.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 07-16-2004, 06:50 AM
SoCal Driver's Avatar
The power windows in the 944's turn off with the ignition key. If they don't then the relay has failed or they have been rewired. Could be the ignition switch but you would have other problems too.
Which takes me to my point: Many 944's have gone under the knife of the PO when simple to fix electrical problems occur. This tends to take a simple repair into the realm of next to impossible.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-16-2004, 07:17 AM
Drivers door speaker quit. Discovered that the insulation had cracked in the concertina and that one wire had sheared at a crack.
Fixed by splicing in a new length of wire.
I was looking for the cause of my mirror motors not working but those wires appeared to be intact.
'87 924S 5sp
Slowly recovering from a warped head
Old 07-16-2004, 07:53 AM
Burn the fire.
Brando's Avatar
Fix to electrical probs:
New battery and replacing with new OEM wiring harnesses
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 07-16-2004, 12:24 PM
bearone2's Avatar
before you by an alternator/regulator when the batt dies, make sure the alternator lite comes on when you turn on the key.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 07-16-2004, 01:48 PM
entertaining the idea
UconnTim97's Avatar
Replaced motor for windshield washer a few weeks ago. Just finished putting in new check valves. You don't realize how often you need the windshield washers until they no longer work...lol
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 07-16-2004, 02:02 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
on 2 of my past cars i havent had them where they workedone day one of my friends asked, hey your windshield is dirty didnt you just put new washer on? i had completely forgetten about them.
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 07-16-2004, 03:16 PM
Did you ever find out why the mirrors didn't work?
Old 07-16-2004, 04:28 PM
