Tdc??? Help
OK. Just starting my belt job and I am having trouble finding TDC. I cannot see the line through the square hole in the bellhousing. I have lined up the reference on the bottom of the housing (see photo) and I am very close on the cam pulley. (see photo). I am thinking of going ahead like this. Should the cam pulley mark line up perfectly? I looked at it and it seems like the next tooth would be further off then this one. Why can't I see anything through the hole???? Are there any other ways I can check before I start????
1987 944S
2000 passat 1.8T wagon
Old 07-17-2004, 09:27 AM
AFJuvat's Avatar
You are fine, proceed.
The 944S pulley has a little bit of slop in it - the keyway is wider then the key - gives you +\- about 1 tooth on the crank pulley.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-17-2004, 01:17 PM
now I get in there and I realise that I have to take off the crank pulley to change the waterpump. I really didn't want to have to do that. Also, I cannot get to the bottom bolt for the tensioner without taking off the pulley.
1987 944S
Old 07-17-2004, 04:00 PM
AFJuvat's Avatar
Yes you can, you just need to have the tensioner fully extended to get at them.
Yes, you do need to remove the crank pulley - 24mm bolt, torque to 205NM. Make sure you have a flywheel lock
AFJuvat
Old 07-17-2004, 04:32 PM
SoCal Driver's Avatar
Cut the plastic belt housing in half. Don't need to take either the balance or crank pulleys off.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-17-2004, 07:47 PM
