entertaining the idea
UconnTim97's Avatar
Early DME ?
I am looking into getting the FR Wilk chip...what DMEs are compatible with an '83? I want to be able to send one to have the dual chips installed....
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 07-19-2004, 03:41 PM
You will need one from an 83, an 84, or an early 85. They all have the same part number.
gb
Good luck, George Beuselinck
Old 07-19-2004, 05:25 PM
UconnTim97's Avatar
Thanks...that is what I was thinking, I just wanted to be sure.
Old 07-19-2004, 05:37 PM
If you want to get really"trick", replace the DME and AFM with parts from an '85.5 to '87 ('88 and later are WAY different).
You can chip the late model DME and keep the original as a spare.
If you go this route you need to replace BOTH the DME and AFM because the early and late parts are not compatible with each other.
Beyond that this is a "Plug and Play" upgrade.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 07-20-2004, 05:59 AM
