Stan944's Avatar
Aligning rear toe
I want to align the rear toe, and am wondering if anybody wanted to share his/her experience. I know the right rear toe is out of specs. I can measure the alignment using strings and basic geometry.
The question is about the procedure.
I bought the special tool for the alignment. I've seen diagrams of the control arms, but I don't have a full understanding how the adjustment works. I know there is a slot where I plug the special tool to align the toe. Does the toe adjustment change the camber considerably? Right now I have -1 deg rear camber, and want to leave it this way.
Do I need any special wrenches? (I have several kinds of "regular" wrenches).
Any comments/suggestions would be welcome.
1983 red Porsche 944
Old 07-27-2004, 06:54 AM
SoCal Driver's Avatar
The large bolts are really difficult to get loose with the car on jack stands as it's hard to get good leverage. You might have to put the car on a local lift to loosen the bolts. If so then calculate how much you have to move the wheel fore/aft to get the toe you are looking for while the car is on the lift.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-27-2004, 09:09 AM
gearhead290's Avatar
Send a message via AIM to gearhead290
Don't do your own alignments, it isn't accurate enough. Personally, after driving many cars with very different alignment settings, I tend to like -2 or -2.5 degree camber front and rear, 0 toe all around (kills tires fast), and about 6 degrees caster. This is a very agressive set-up though, so I wouldn't use something that extreme if you don't track the car regularily.
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 07-27-2004, 11:38 AM
Stan944's Avatar
Thanks for the advice.
SoCal Driver: do I need any special (extra thin, extra large, etc.) wrenches?
gearhead290: I want to make the rear toe within manufacturer's specs. I autoX this car, and anything outside the specs would bump me out of the stock class. One day i might go agressive, but not yet.
I do my own alignments :-). I believe I do it accurately enough. I tested it once: I measured the alignment a few weeks after having it done in a shop, and came with almost identical numbers. Alignment is tedious, but it's not rocket science...
Old 07-27-2004, 12:05 PM
Stan944's Avatar
OK, I've done it. The procedure is not very difficult, as long as you trust your alignment procedure (I do...). The toe adjustment tool is a must. I changed the right rear toe from +0 deg 20' to -0 deg 1' (the specs are 0 deg +/- 5 '), while preserving the camber within specs. The range of toe adjustment turned out to be about 30'. The left side was fine, so I didn't touch it.
Ironically, I don't feel the difference while driving, but hopefully it will help im autoX.
Old 08-05-2004, 08:12 AM
