944freak's Avatar
Send a message via Yahoo to 944freak
Question why wont it start?
About a year ago I put a 1986 na motor into my 1983 na. It wouldnt start then and I havnt had a chance to work on it untill now. I tested the fuel pump and it was bad so I bought a new fuel pump and installed it. It still wont start but it is getting fuel and fuel is spraying from the injectors. I pulled a spark plug and cranked it over and it has spark. So I have fuel and fire what else could be wrong?
1983 944
Old 07-21-2004, 05:06 PM
AFJuvat's Avatar
DME relay
Make sure all of your sensors are connected properly
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-21-2004, 08:14 PM
944freak's Avatar
where is the relay and is the the same one as in the 86 turbo cause i have a spare?
1983 944
Old 07-21-2004, 08:30 PM
AFJuvat's Avatar
same relay
second from left, top row
AFJuvat
Old 07-21-2004, 09:07 PM
SoCal Driver's Avatar
How do you know the injectors are working?
How did you test for spark?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-21-2004, 10:40 PM
944freak's Avatar
i pulled the fuel rail off and saw the fuel spray and to test for a spark i pulled the plug and cranked the motor with the plug in the plug wire. Today I installed a new DME relay.......When it fires its like the intake valves are open or something because its like it belches back out the intake. I cant find anything showing where the plug wires go on the rotor cap but I have them on there the same as they are on the 86 turbo. Since i wasnt sure i moved the number 1 plug wire to the upper left plug on the rotor cap and put them on 1 3 4 2 and it would fire and I would get little puffs of smoke instead of firing out the intake....i am confused.
1983 944
Old 07-22-2004, 06:54 PM
944freak's Avatar
The puffs of smoke I mentioned above were out of the muffler
1983 944
Old 07-22-2004, 07:53 PM
944freak's Avatar
bump
1983 944
Old 07-23-2004, 09:56 AM
Rotor rotation is clockwise as standing in front of the car looking at the dist cap. Number one wire goes in the 5 o-clock location.
Pull the dist cap and make sure the rotor is not burned through between the tip and the center. Make sure the tip is not burnt down to the plastic. Check that the rotor screws are still intact.
Old 07-23-2004, 04:53 PM
944freak's Avatar
Ok I have the wires on correctly and when it fires it seems the pressure excapes through the intake. The rotor and cap are in good condition. I think im going to take the timing belt cover off and check the timing and if its not that would that leave the speed and reference sensors?
1983 944
Old 07-23-2004, 05:30 PM
944freak's Avatar
I really hope not...... this was pretty much a fresh motor last year
1983 944
Old 07-23-2004, 07:43 PM
944freak's Avatar
my number 1 wire is on the bottom right plug 1 3 4 2
1983 944
Old 07-23-2004, 07:56 PM
944freak's Avatar
clockwise when im facing the distributor
1983 944
Old 07-23-2004, 08:19 PM
944freak's Avatar
is there any chance it could be the speed or reference sensor
1983 944
Old 07-23-2004, 08:22 PM
944freak's Avatar
Yea the rotor looks brand new, I dont think ill have a chance to work on it any more till monday but i will unplug an injector and try that on monday.
1983 944
Old 07-23-2004, 08:56 PM
944freak's Avatar
Well I trusted the seller because he wrecked his car sideways into a telephone pold. I saw pics of the car. Supposedly the motor has an aftermarket cam in it and the clutch was brand new. I looked at the clutch and it appeared to be new. You never know anymore though. I still have the old engine and im not sure if it is damaged or not. I should pull it apart and see if the valves are intact in case i have to swap heads or something. Thanks for the tip, I'll be sure to try that one out on monday too.
1983 944
Old 07-23-2004, 09:08 PM
adida(r 944)'s Avatar
if you need to know if you got a stuck valve run a compresion test on it, should take 20 mins.
FWIW when i did my 86 engine into 85/1 car i had the same problem, no start and blowing black smoke. untill i used the 85/1 DME, Intake Manifold/throttle body, AFM, and Altenator. for some CRAZY reason the parts i just mentioned that were on/for the 86 engine made the car not start and blow black smoke. i dont know what exactly i did there but i got er running by switching those parts. wierd huh, i thought it was...
good luck
85/1 944 project/restore/upgrade in process finnaly:
Bursch headers and cat delete pipe. fiberwerks front bumper and rear wing
cant spell forgive my "hukt on Fonix" it workt gud four mi
in the process of buying a car and a half garage with a detached house and fenced in yard
03 Eclipse GS
Old 07-23-2004, 09:22 PM
I have an 86 engine in an 83. Didn't have to change out a thing in the 83 to get it to run. Realy no difference in the basic engine as far as the wiring with the exception of the temp gauge sender. Then you just use the larger of the two pins on the newer sender.
Old 07-24-2004, 07:59 AM
944freak's Avatar
i used the 86 motor and the 83 afm.
1983 944
Old 07-24-2004, 11:00 AM
944freak's Avatar
right It has an 83 dme and 83 afm with the 86 engine.
1983 944
Old 07-24-2004, 08:12 PM
