Red face Engine overheating...NEED HELP
I have a 1984 944. I've owned it for some time so I am familiar with the constant fixing that must occur with this car. My latest problem is baffling me though. Last week I replaced the water pump and thermostat and today I replaced the radiator. The temoerature guage is still climbing up to the red befor the fan comes on. Then it only cools down to just above the third line. I'm freaking out. I don't know what else to check so if anyone can help me, I would appreciate it. Thanks.
Old 08-05-2004, 06:44 PM
Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
Did you replace the temp sensor? Or thrmo-switch for the fan?
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
Old 08-05-2004, 06:48 PM
I didn't think of those. Thanks. What about fuses or relays?
Old 08-05-2004, 06:53 PM
a fouled fue or relay would get either no signla or an intermitent "normal" signal
Old 08-05-2004, 06:56 PM
fast924S's Avatar
Send a message via AIM to fast924S
Make sure the fans are working right, Is only one fan running or both?? Did you forget to plug one in??? Did you get all the air out of the system?? Try flushing the block to remove any debree. Check all hoses too.
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Both of the fans are plugged in but only one fan is working and is intermittant. On occasion , it won't turn on. I flushed out everything and the hoses are good. Bled the system so there shouldn't be any air.
Old 08-05-2004, 07:02 PM
only the A/C fan.
Old 08-05-2004, 07:08 PM
cool, thanks
Old 08-05-2004, 07:17 PM
