winter-hater club member
nynor's Avatar
DME question
what year(s) DME can i put in my '83 944? right now it has the stock unit, no mods, etc. if i were to put an '86 or later DME in it, what else do i have to change?
"COOL PRIUS!" - Nobody Ever
Old 08-12-2004, 03:07 PM
IIRC...mass air sensor, prolly idle stabliser valve too...then years 86-87 should work
anything else anyone? will the '88 work? (with higher comp. ratio); '89? (2.7 engine) etc
Tom
Early '85 944
Old 08-12-2004, 05:50 PM
entertaining the idea
UconnTim97's Avatar
I think you can use an 83, 84, and early 85...otherwise you will have to do the changes that carsontc mentioned
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 08-12-2004, 09:03 PM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
Hi nynor,
YOu'd probablly want to refer that question to Socal or F.R. Wilk.. wilk makes chips that will improve your Porsche. Better accelleration and throttle response all around.. he's THE guy to talk to..
FRank B
My car is naughty
Old 08-13-2004, 04:05 AM
nynor's Avatar
what is a(n) IIRC?
Old 08-13-2004, 08:58 AM
chat acronym...see:
http://www.techdictionary.com/chat_cont1.html
Tom
Early '85 944
Old 08-13-2004, 10:09 AM
nynor's Avatar
i see...
so, IIRC, socal or some other venerable person, stated in a previous post, stated that they were using an '86 DME in their '83 or '84 944 without changing anything else. or they stated that they changed the MAF and the DME because the voltage is different for those years.
Old 08-13-2004, 10:48 AM
Chris_924s's Avatar
The DME for the 83/84 should be 944.618.111.X
The 944.618.121.x version is for the 924S and later 944's.
HTH.
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 08-15-2004, 09:31 AM
nynor's Avatar
re frwilk's reply:
i want to do this because i can get the AFM and DME for less than $100. then i can get a powerprom2, without having to solder anything, and i think i save a few bucks.
Old 08-15-2004, 11:25 AM
