What did I do this time?
Yesterday the air conditioning was working great... actually today it's still working just fine... it just won't come out of the upper vents.
All I did was remove and clean the ground at the back of the engine. Started it up and turned the air on. you can hear it running, and down by the passenger side foot space there is a fan spinning like crazy... but no air comes from the vents ![]() any thoughts on this one? (I am sorry for being such a pain but everytime I turn around something isn't working and I just don't know why) As always thank you for your input. Robert
1983 Porshe 944 N/A 5sp Guards Red |
could it have something to do with the vacuum switch that opens the vents? not too familiar with exactly how the controls operate the vent, but I bet there is something somewhere in this forum if you search for it.
Used & Abused
Are the 2 upper slide knobs pushed together? Does the defrost or floor vents work when the knobs are moved around?
83 - 944, daily driver 62 - VW Karmann Ghia, never moving restoration "Oh Bother," said Pooh, as he chambered another round. |
In the Fires of Hell.....
You likely dislodged the vacuum line for the heater control valve that is located right in that ground area. That would make it so that you would have hot mixing in with your cold.
The ground / vacuum line should not have any effect on your vents, but there is another vacuum line back at the firewall that may have become dislodged that would. Do a careful inspection and you will likely find the culprit. Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Behind the glove box is the vacuum line that opens and closes the flaps to push the A/C through the vents. It runs through the firewall to a blue/black vacuum solenoid type thing right beside the brake fluid reservoir. something most likely got pinched or disconnected. Start under the hood and trace the vacuum line.
1983 944 This was probably posted from my phone, so please excuse any typos. |
nightheart,
Thanks!!! I'll check that out in the morning.
Okay I found the point that opens the upper vents... but my hose only goes about 6 inches to a vacuum solenoid.
this isn't the first thing I've found that isn't where other 83 944's are. All my major things are in the right places but several others aren't where people say they are on their cars. anyhow I did get the air back working on the upper vents. Thanks
