Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
Coolant question and Idle question
Okay...I'm not a fan of antifreeze. Hate it, actually. Reduces cooling efficiency...makes a mess...one more toxic chemical you have to store around your home...etc. I like to run distilled water for a number of reasons. So will distilled water cause any harm to the engine in combination with a water wetter or something to lube the pump?
~also~
My idle is odd. If I rev the engine it climbs propperly, but the engine speed doesn't return. Once I let off the gas the engine stops deccellerating at arouns 2200rpm and very slowly goes back to 900. What do I ned to check/adjust?
Old 08-25-2004, 04:19 PM
adida(r 944)'s Avatar
distilled water will only harm your engine if the tempertures fall below 32 degrees F.
as for your odd idle play around with your throttle body (im thinking the return spring is weak) and maybe try FR Wilks 944na shudder tech article, dont think you got the shudder but may help you out.
85/1 944 project/restore/upgrade in process finnaly:
Bursch headers and cat delete pipe. fiberwerks front bumper and rear wing
cant spell forgive my "hukt on Fonix" it workt gud four mi
in the process of buying a car and a half garage with a detached house and fenced in yard
03 Eclipse GS
Old 08-25-2004, 04:50 PM
yeah if it freezes, it'll cause damage. That prompts propper twice a year maintanance...like the rest of my cars. In late October, everything gets either a 50/50 or 25/75 mix. March gets distillled water.
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
Old 08-25-2004, 04:54 PM
bearone2's Avatar
Cool
you may not like it but it raises the boiling temp, provides corrosion protection and i've heard it does get hot in texas.
i don't think you're doing yourself any favors with distilled water.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 08-25-2004, 05:12 PM
antifreeze has a boiling temp of 138* (usually) ina 50/50 mix, and it holds temps very well.
Water boils at 125* under pressure and cool much faster and does not hold heat well. Water is a much poorer conductor of energy than antifreeze.
Old 08-25-2004, 05:20 PM
http://www.carcraft.com/techarticles/53738/index4.html
lots of stuff here
http://www.fordbarn.com/earlyv8/forum03/messages/58080.htm
Also, as far as the raised boiling point...you do know that a stiffer rad cap will do the same, right?
Old 08-25-2004, 05:38 PM
flangermog's Avatar
So why you askin Mak? :-)
(x)'89 944 S2 Cabriolet (Guards Orange) :
( )'90 944 S2 (Maraschino Dead!) :
( )'89 Audi 90 Quattro 2.3 20V :
( )'92 Renault Clio 1.4 :
Old 08-26-2004, 01:13 AM
because the block requires special coolants...phosphate free I believe? Are water wetter and such substances harmful?something HAS to be in the system to prevent corrosion and keep the pump lubed..
Old 08-26-2004, 07:12 AM
max29a's Avatar
When I unplugged my throttle switch on the underside of the throttle body it caused the idle to do that, no matter how high the rpms were if I let off and pulled out of gear it would just kind of slowly creep back down.
So I would say to check your throttle switch.
1985.5 944 NA - 270k miles!
2001 suzuki sv650 - 37k miles
oil change done at 270k
timing belt done at 240k
Old 08-26-2004, 08:06 AM
SV650...excellent bike...
I'll check the throttle switch...thanks.
Old 08-26-2004, 08:20 AM
I had a very similar problem, and it turned out that the hood insulation was sagging right above the throttle cam and caused it to return oddly. Hopefully this is your problem because it is a super easy fix.
Nate
'84 944, '05 GTO
Old 08-26-2004, 08:31 AM
not so simple....
The throttle body snaps shut very quickly...but the RPM stay up there momentarily. Any other ideas? I want a rev-happy car....
Old 08-26-2004, 08:27 PM
I just took the intake hose off to make sure the butterfly wasn't hanging anywhere. The spring is tight. It's decelleration seems to have no bearing on the throttle body position. I've adjusted both the throttle stop and the idle screw and have gotten nothing. What now?
Old 08-26-2004, 09:02 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
have you checked the throttle cable? Perhaps it is too tight?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 08-27-2004, 05:35 AM
TCMdocs944's Avatar
Vacuum leak?
A plethora of idle problem can be caused by one of those.
Phosphate free is because of the aluminum head no?
The biggest worry I would have is corrosion with plain ol H2o
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 08-27-2004, 05:41 AM
Don't you run the risk of blowing the seams on the radiator tank if you run too high a cap pressure?
BTW, are those temps you're citing in Farenheit degrees?
Old 08-28-2004, 05:04 AM
Celsius
Throttle cable is great...the butterfly closes completely. I've tried to find a vac leak but have been unsuccessful.
Old 08-29-2004, 02:48 PM
Sorry guys,I know this thread is ancient but I am having the exact same hanging idle problem on my 87 924S. I am stumped on this any help would be appreciated!
Old 07-12-2010, 01:32 PM
The bigger problem is that Texas's water is defying physics and not boiling at 100 c anymore.
1983 944 - project mode
2002 Ford F150 - every other daily driver
1976 Honda Goldwing - the other days
Old 07-12-2010, 01:48 PM
Mine was an intake manifold leak. It's a 25 year old car by now...it's probably never been done, and it's something that should be done on occasion. Strip the intake and replace all the gaskets and vacuum lines. Won't hurt to replace all the exhaust gaskets, either.
Old 07-13-2010, 06:58 AM
