Problem: If the wiress on the o2 are not there....
The o2 sensor on my early '85 944 has broken off will this prevent the car from starting???? I have not started the car in years and I wanted to know if this could be the reason the car was not starting.
early '85 944 -project car, sort of works.
Old 08-27-2004, 10:20 AM
TCMdocs944's Avatar
No
Well, I am pretty sure no
If the DME isn't getting a reading or gets a messed up one from the O2 I think it just over-rides and runs a little rich...decreased gas milage is about it.
What are the symptoms of the no start? Cranks?
Let us know and we can help you out.
Not to harp on it but let me be the first to say...If the belts are questionable at all change them before you get going. Dryrot / age may not cause it to snap but it can shear off the teeth. I know from experience.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 08-27-2004, 10:58 AM
The car is make a hard cranking sound, the starter seems to be turning the car only briefly. Also, the fuel pump does not seem to be going on when I turn the key. Could a lack of lubrication in the cylinders be making it harder to turn (cause by sitting)?
Old 08-27-2004, 12:39 PM
