how do I drop the tranny?
ok so after much deliberatoin and help from you guys I've decided to try to drop the tranny to pull out the drive shaft, then lift the engine out of the car. my questions is, before I do this, how do I do this? I get out of work at 4:30 so hopefully someone will have read this and been able to help me out... how many bolts? do I have to remove the exhaust? where are the bolts, after I drop the tranny how do I get the driveshaft to come out of the bell housing? thanks for the help guys.
Old 08-27-2004, 07:49 AM
jm951's Avatar
To drop the tranny-
1) unbolt cv joints and remove axles
2) unbolt shift rod from tranny and shifter
3) unhook speedometer and reverse lights connections
4) unhook driveshaft coupling to torque tube (inside tranny bellhousing)
5) support tranny
6) unbolt tranny mount (on top of tranny 2 bolts)
7) unbolt tranny (4 bolts)
8) move tranny back and down
9) move tranny out from under car
10) unbolt t tube from engine bellhousing
11) slide t tube to rear slightly, rotate 180 and slide further back
This should take about 2-3 hours if you work at a steady pace and haven't done it before.
HTH
86 951- again on the road, but needing some more TLC
82 931- again among the rolling
"If yer paint aint chipped, you aint passin nobody."
Old 08-27-2004, 08:00 AM
thanks man, great step by step, your awesome.
Old 08-27-2004, 08:10 AM
ae1969's Avatar
Send a message via ICQ to ae1969
... and follow it step by step..... example dont do 7 before 4.
Also you can tie the axles up once you have disconnected them from the tranny. No need to completely remove.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 08-27-2004, 08:46 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
One or two good burnouts ought to do it. . .
Black Cars Matter
Old 08-27-2004, 09:05 PM
I like driving in 5th at about 6grand then downshifting to second, at least one end of the car will fall out onto the interstate
1985/late 944
Old 08-28-2004, 08:33 PM
