70SWT's Avatar
ignition coil testing procedure
Digging into the non-starting 83 944 I have inherited...I have its coil and another spare coil. Resistance across the terminals of each is right at zero on the ol' multimeter. I understand that there should be about 5 ohms of resistance in the coil. Is there a better way to test it?
2018 911 Carrera coupe
1972 911T targa
Old 08-29-2004, 07:53 AM
70SWT's Avatar
FR -
Already did that - fuel pump is functional...looking at ignition now...
1972 911T targa
Old 08-29-2004, 06:01 PM
SoCal Driver's Avatar
Do you have 12 volts at the coil with the key on? If not it's the ignition switch.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-29-2004, 07:16 PM
70SWT's Avatar
Coil was probably bad. Started right up after swapping in the spare coil. Runs a hair rough and the idle needs to be set higher or the idle regulator looked at, but it "driveway drives"...Phase I of the saga thus endeth...thanks for the suggestions, guys; let's see what else she throws at me, as it's always fun breaking in a new acquisition...regards Al
1972 911T targa
Old 08-29-2004, 10:53 PM
How are the belts? The timing and balance belts that are behind the black plastic cover. If you don't know you had better change them before you go any further.
Old 08-30-2004, 07:11 PM
I know a guy that has the equipment to test that coil, he builds racing ignitions pm me for the address
1985/late 944
Old 08-30-2004, 08:07 PM
70SWT's Avatar
I'm doing what is for me the standard stuff on getting a new 944 without irrefutable maintenance documents (this is about my 20th such orphan) - replacing everything on the front of the engine from the block forward (water pump, belts, rollers, seals, t-stat, etc). Cheapest insurance you can buy on these cars...I have fortunately never had one with an ignition problem until now, and this turned out to be a realtively easy fix...and I indeed set the idle with the screw already as well, and the bad coil has been replaced, but thanks for the help guys...
1972 911T targa
Old 09-01-2004, 08:50 AM
