trailing arm
Here's my situation:
I have an '86 na with the symtoms of a bad passenger side rear wheel bearing. The car has not led a pampered life from the previous POs. On that side the control arm has suffered some damage, there is actually a tab that has been broken off that makes it impossoble to have properly working emergency brakes. I was told by a Pelican parts employee that the trailing arm from my '87 924s is the same as my '86 control arm. Can anyone confirm this? Because my plan currently is to swap control arms and hoepfully solve both my bearing and e-brake problems at once. I am assuming I will need to use my 944 brake hardware to allow the use of my early offset wheels. Is this plan going to work?
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 09-07-2004, 04:40 AM
Thanks for taking the time to check that out for me.
Old 09-07-2004, 09:56 AM
