White/Green Switched 12v wire:
Alright, real simple quick question for ya. I have a melted green/white wire that was behind my stereo. As far as I can tell its the 12v switched wire. Any idea where this runs back to? FWIW its an '83...
Old 10-04-2004, 09:04 AM
bump, anybody? Does it run to the ignition switch or something? Im having a hell of a time following it and cant find ANY white/green wires in ANY schematics I have looked at.
Old 10-04-2004, 01:23 PM
flangermog's Avatar
This sounds like non standard wiring (probably why nobody has answered). I don't understand what it is you're trying to do. If you want to replace the wire (which you should if it's melted) can't you just follow it to where it goes and replace it?
(x)'89 944 S2 Cabriolet (Guards Orange) :
( )'90 944 S2 (Maraschino Dead!) :
( )'89 Audi 90 Quattro 2.3 20V :
( )'92 Renault Clio 1.4 :
Old 10-06-2004, 06:07 AM
Zero10's Avatar
Send a message via ICQ to Zero10
The switched +12V on my radio is white/green as well, and it's an 86.
I don't have the wiring diagrams handy, but I would imagine it comes from the ignition switch.
Probably from the switch, to a fuse, to the radio, or perhaps it's fuse, switch, radio.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 10-06-2004, 11:05 AM
Well, I just found an EARLY wiring diagram that says mine should be Red for constant and Red/Black for switched. My goal is to find out where the hell it goes so that I can replace. Now im not thinking its for the radio, so im lost. Now I dont know what circuit it is on.
Old 10-06-2004, 11:42 AM
Zero10's Avatar
Hmm, IIRC, it is power to the clock.
I remember when I tied into it, I didn't see the other white/green wire, and I only connected to the one, and my clock would never come on.
Buy my parts!
Old 10-06-2004, 01:30 PM
don't think it's for the radio
http://www.pelicanparts.com/944/electrical/944_84_3_1.jpg
no wt/gn there
here's the clock
http://www.pelicanparts.com/944/electrical/944_84_5_1.jpg
no wt/gn there either
but there is one here
http://www.pelicanparts.com/944/electrical/944_84_4_1.jpg
for the rear defogger
Tom
Early '85 944
Old 10-06-2004, 05:54 PM
I figured it out. Turns out a lot of these diagrams have it labelled wrong. Its a green/GREY wire from the fuse block to a 6 pin connector where it splits off and it calls it a green/blue wire or somthing, but I have confirmed where all it goes, it hits the oil pressure gauge light, glove box light and ashtray light, and maybe somthing else, dont remember. The good thing is it looks like the only wire that melted. And everything except those above lights now works and no more melting fuses. So as soon as I rewire this it should all be good. Now I just gotta figure out why the hell the car wont start!!!! Agh!
Old 10-07-2004, 12:47 PM
