attn techs, need some help with a problem
Had somone bring me there 86 that they just got off of e-bay. The car would not start, and replacing the dme relay got it going. At idle, now that the lifters are pumped up, is pretty quite. Give it a little throttle, loud rattle. At idle the motor will have no noise, then it will get a metallic tick from the top and it will idle down. When the metallic tick from the top goes away about 4 secs later, it will get a muffled, but slight, knock from down lower.
When the drain plug was pulled, it was pretty clean with just a few "dust" size pieces. If a lifter had gone bad, is it possible, that you can get some vavle-piston contact. If a valve spring set has gone bad, same question. Worst case, con-rod bearings need replacing. Oil pressure is good though. When the car starts, 4 bar. After the car reaches temp, only drops to 3 bar at idle. Good compression on all 4, 160 But here is another thing, white smoke out the tail pipe......
86 944 daughters 88 944 step-sons 07 Ranger 4x4 I have tons of spare parts, let me know what you need. |
woops, I messed up, I had already posted this!!!!
