Can't remove license plate bracket
On the front of my 1985 (early) 944, I can turn the screws (barely) but they don't back out and they don't seem to be letting go of whatever they are holding on to.
1985 (early) 944
Old 01-10-2005, 04:32 AM
adrian jaye's Avatar
have you tried soaking them in some penetrating fluid,
if not then CAREFULLY drill them out ?
HTH
Ade
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 01-10-2005, 05:56 AM
btsave's Avatar
Easy fix, remove from bumper (two bolts located on bottom - use socket wrench).
Then it's easy to use a socket to stabalize the inside bolt.
Takes about 15 minutes.. Use rubber stop for remaining holes.
Old 01-10-2005, 07:13 AM
