Can't remove license plate bracket
On the front of my 1985 (early) 944, I can turn the screws (barely) but they don't back out and they don't seem to be letting go of whatever they are holding on to.
1985 (early) 944 |
have you tried soaking them in some penetrating fluid,
if not then CAREFULLY drill them out ? HTH Ade
----------------------------------------------------------- The fear of God is the begining of wisdom <>< NotJustPorsche Subscribe: notjustporsche-subscribe@yahoogroups.com |
Easy fix, remove from bumper (two bolts located on bottom - use socket wrench).
Then it's easy to use a socket to stabalize the inside bolt. Takes about 15 minutes.. Use rubber stop for remaining holes. |
