924 (the one with the 2.0L engine) use a smaller torque tube than 944. They also break. Again, changing the final drive ratio without anything else for the street is not gaining anything. For the more power scenario;buy a 944 Turbo, which will be cheaper and also work. Installing a Turbo engine into a NA 944 is not a five minute job and if you have to pay someone; will end up cheaper to buy a complete and usuable 944T. Early NA 944 can and do break the ring and pinion, and the gear ratios are wrong for the street and for what you intend. Of course, installing a 944T engine in a NA means you intend to drive the car faster so suspension upgrades will also require doing. Again, easiest and most cost effective is to buy a 944T and drive that.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 01-19-2005, 03:54 PM
fast924S's Avatar
Send a message via AIM to fast924S
I have already run a 4.11 rear final drive ratio in my 87 924S, got the gear from PowerHouse2 cost me approx $900 with shipping, then I had them installed and my tranny rebuilt, total cost $1600, The different final drive was sweet for back roads, I was alwasy in my powerband, but if you where up on the highway say hello to 4,500rpm all day long. Anyway the new gear ratio didnt last to long, It blew up about 3 weeks later because the guy who installed it setup the pinion depth wrong. Anyway there is a ton of stuff you can do to a NA, just gotta have the time and money
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 01-19-2005, 05:31 PM
ahh…so it was replaced under warrantee then…btw, who did the work?
Tom
Early '85 944
Old 01-19-2005, 06:28 PM
entertaining the idea
UconnTim97's Avatar
FRWilks chip did wonders for the acceleration, along with a new throttle cam and a good tune up.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 01-19-2005, 07:09 PM
Exactly what UconnTim97 said works well for most people who use their cars normally. After that it gets to the "well, I can't drive it now because it broke again" phase.
Old 01-19-2005, 08:25 PM
Hey thanks for all the info. I don't think I'll bother even attemping a turbo upgrade there then.
Presumably getting one of this chip systems, or a drive computer, replaces the dist cap with a digitaly controlled ignition system?
Cheers,
Jon
Oh about my insurance - it's £3500 a year Third Party only. I am 18 though and this car is category 20 in the insurance groups. By the way - why on earth does having a wife lower your insurance premium?
Old 01-20-2005, 04:20 AM
Oh one other thing - I don't want to drive faster - I want the car to accelerate faster - i.e reduce the 0-6 time.
Thanks,
Jon
Old 01-20-2005, 04:21 AM
strath44's Avatar
Jon run a quote with these guys below or call them I'm with one of the two can't remember which. Getting your car on a classic policy will significantly reduce the price also if you limit the milage say to under 10k or even 7k a year. Almost all years of the 944 classify for classic insurance now. Going to a normal insurer is the worst because as you say the car is group 20 its a Porsche and your 18 not a good combination in the eyes of the insurers!
Lancaster Car Ins
Heritage Car Ins
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 01-20-2005, 04:31 AM
tifosiman's Avatar
Originally posted by Z-man
Mark:
Most people don't think about swapping in a whole (and complete) 951 motor - instead, they think they can just slap a turbo on their 944 n/a and voila: 944 turbo! Turbocharging a motor is a lot more complicated than that: there's issues like compression, timing, air flow metering, chip....etc.
But even your 'solution' of swapping in a 951 motor into a 944 n/a body isn't that easy an undertaking. First off, if you are doing this to an early (pre 85.5) model, the front spindles won't match up, as already stated above. Second: the brakes on a 944 n/a won't handle the extra power of a 951 - which is exactly why the factory went with bigger, 4-piston Brembo calipers and larger rotors. Third - there are some other things that don't quite match up like the air intake location, the oil cooler...etc.
And finally: the biggest reason why a 951 motor swap isn't worth it is because by the time you add together all the costs, it is will be more expensive than buying a 951 to start with. 951 prices are beginning to drop under the $10k range. Even if you have a 944 n/a body and a 951 motor, you are better off selling the 944 n/a body and buying a 951 shell.
Just my $0.42,
-Z-man.
Let's not forget that swapping in a 951 motor will require a 951 transmission. The 944 transmission is not up to the task.
1985.5 944 Club Sport
My P-caronline Profile
"A good time to keep your mouth shut is when you're in deep water. "--
Sidney Goff
Old 01-20-2005, 07:23 AM
Goku's Avatar
Nuff Said.
ßrªÐL£µ
88' 951 - Wolf's now :'(
Reluctantly crouched at the starting line...
Old 01-20-2005, 07:31 AM
Mike(dat's me)'s Avatar
Because depressed, overburden, broken down, nagged to death husbands don't drive as fast as wreckless, adrenaline pumping, show-off, still full of life men.
In other words, we get beat down and aren't as risky.
Mike
"When you're walking on thin ice, you might as well dance"
944 wannabe
Old 01-20-2005, 07:45 AM
I doubt whether installing another ignition system will really change acceleration performance. 944 models were not designed for 0-60 times (as was the case of most Porsches) but crusing at high speeds, excellent handling and the ability to be used competitively at the race track. If you want to work on the 0-60 times, then basically you need another car.
Old 01-20-2005, 07:54 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Registry Editor,
1) FRWilk PowerProm 2 chip - BY FAR the best performance increase I have done. Smooths out torque curve and gives a noticeable increase in accelleration.
2) Suspension/Brakes - The faster you can stop and the faster you can take corners, the faster your car will be
3) Lighter=faster - my next course of action
4) DE events
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 01-20-2005, 08:22 AM
fast924S's Avatar
Carsontc- Thats the big problem, The guy who installed the gears "Smith Brothers Transmisions" Says the gear was made bad so I sent pics to the gear guy and he said it was setup wrong and back and forth we went for weeks so then I just gave up and took it from behind like a man. But at least the gear guy "PH2" said since I went threw soo much BS that he would give me the next set at there cost but I never went for it and now Im running a tranny from a 85.5 944 in my 87 924S
Old 01-20-2005, 05:31 PM
Send a message via AIM to bluebullet
Originally posted by CJFusco
Registry Editor,
4) DE events
what is a DE event?
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 01-20-2005, 09:14 PM
UconnTim97's Avatar
Driver's education
Old 01-20-2005, 09:18 PM
Writer/Teacher
CJFusco's Avatar
PCA holds a handful of Driver's Education events every year at area racetracks - Lime Rock, Pocono, etc. - and what you do is tackle the track with an instructor riding with you. A lot of people claim they have had no idea what their car can do until they took it to a DE.
I have yet to do one
Old 01-21-2005, 07:19 AM
Banned
funny how you guys think inside the box ONLY
one of my other cars is a volvo 245turbo wagon [miniSUV]
and volvo guys add turbos to n/a motors without a care
and the fastest ones are the N/A +turbo motors
yes they need an intercooler [bigger the better]
and tuning and tricks like a megasquirt box {aftermarket custom CPU} added
but they have a canDO and lets try IT mindset
that is lacking here
Old 01-21-2005, 07:47 AM
strath44's Avatar
yes but thinking within the box again.... we're not talking about volvo's we're talking about '44s and unless you want a boneshaker that will cook its brakes on the first bend then the components and money needed to make the project successful outweigh putting up with your n/a (which with the various mod's summarised by fusco is pretty good) for a bit longer and saving a few more cents for the real thing!
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 01-21-2005, 08:33 AM
True some people do modify Volvos, no reason not to..maybe that's because there are more a then a few parts available..why is that? it's a bigger market and the engine as installed has potential for fairly large power gains at reasonable cost. Of course, you then have to modify the suspension, gear or final drive ratios and brakes to actually use that power but it can be done. And then how many times do they actually use all that power?
The 944 market is different, otherwise there would be more advertisers in Pelican and elsewhere on the web offering all sorts of parts. But there isn't. One of the reasons; if you want a fast 944, buy a 944 Turbo. For modifying NA models, most owners either aren't prepared or don't have the money to spend. Yes, you can buy some parts and install them yourself, not a problem. Don't seem to see to many "this is fantastic" posts about anything apart from FR Wilks chip.
944s are great cars, they handle, brake and generally work very well and that's what they were designed to do. But the range also includes faster models as the years went on.
Thinking outside the box is such a well-worn phrase that it doesn't mean anything. Yes, one can easily think about changing a 944, but then reality sets in and to radically change the car involves changing lots of parts, and not that many people want to do that.
Old 01-21-2005, 08:43 AM
