Cars & Coffee Killer
legion's Avatar
Timing Belt Cost
I need to have my timing belt replaced this spring. I figured as long as that was being done, I might as well have the accessory belt and balance shaft belt replaced also. Additionally, I was thinking that I might as well have the rotor and points replaced, and the ignition re-timed.
So my question is...what is a ballpark figure for this kind of work? The shop a town over quoted me $1,700 for all of the belts. Seems a little high to me. Is there anything special about having the belts done on an "S" that I should be aware of?
Thanks!
5 liters of VVT fury now
-Chris
Old 02-07-2005, 10:06 AM
tobster1911's Avatar
Speaking from experience that seems way high. That is close to the price for my whole head rebuild (parts + machine work). I did the wrenching myself but that was new valves (16), entire seal kit, Belts, rollers, timing chain tensioner, and machine shop work.
It was less than $200 for timing and balance belts and two new rollers that I needed. AVJuvat could probably tell you the book time to do this work but it took me no more that 3 hrs in my garage. That was with a few pain in the butt bolts.
One thing to consider is doing the timing chain tensioner (under the valve cover). On the S this is the next big time bomb other than the timing belt.
'97 Saturn SL (tiny 1.9L bubble car)
'98 Grand Prix GTP (4dr family car with a bite FOR SALE)
'87 944S (Sold as a German engineerd money pit)
'78 Chevy 4x4 (What I drive when everything else is broke)
Old 02-07-2005, 10:33 AM
legion's Avatar
I'll have to check my records, but I believe the tensioner was replaced when the timing belt was last changed (about 88,000 miles). I'm at 121,000.
-Chris
Old 02-07-2005, 10:52 AM
Only take the car to a shop with Porsche and specifically 944 experience.
With a 944S you should be looking at belts, rollers, water pump, timing chain pads (or tensioner) and some other stuff like oil seals. If the shop estimated around $1700 for that amount of work then it's not far off. It depends on what the car needs.
Saying the shop estimated $1700 for the belts means nothing unless you have a written estimate with all the parts they think you will need.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 02-07-2005, 10:55 AM
legion's Avatar
I know the water pump is very new (within the last 20,000 miles), and the car runs cool, so that isn't an issue.
They simply told me that they charge a flat $1700 and they change all of the belts, rollers, and seals.
-Chris
Old 02-07-2005, 11:23 AM
Zero10's Avatar
Send a message via ICQ to Zero10
I'd walk from that shop.
Just so you know, there are no points, and you can't adjust the timing from the distributor cap in these cars. It's all electronic. Just change the cap and rotor, and you're done. Good to do with the belts, since it has to come off to change them.
$1700 sounds too high for just timing belt job. If it includes chain tensioner and all related parts, then that isn't too bad.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 02-07-2005, 11:40 AM
I agree with Zero on this. It doesn't sound like you are getting accurate information from the shop. Is it a Porsche specialist or just a "we do German cars" type of place?
Old 02-07-2005, 12:17 PM
legion's Avatar
It's a "we do German cars" kinda place. The person on the phone also mentioned that "working on Porsches is a license to print money". I'm 99% sure I won't take my car there. I just wanted to know what kind of price range I should expect so that as I call other shops I could gauge them.
-Chris
Old 02-07-2005, 12:31 PM
Find a real specialist shop and get a written estimate. If they know 944S models you should get a figure around what the invoice will be when repairs are complete.
It's important to use a Porsche specialist shop.
Old 02-07-2005, 12:51 PM
legion's Avatar
There's a shop in Champaign that has been recommended to me. I think I'll call them. Still, it's going to be a hassle to get my car there, get myself back here, and then get back there to get my car when the repairs are complete.
-Chris
Old 02-07-2005, 01:02 PM
i paid 140 bucks labor to have mine done..... I bought all my parts at my advance. and got a roller form a porsche dealer...... THat is way way high.....in my opinion.
85 944. throttle cam. k&n cone. jacobs wires. Msd coil.glass pack... getting ready for drivers ed. daily driver
90 944 S2 cabrio: custom roll bar,18 inch TSW wheels,K&N filter, drilled zimmerman rotors
Old 02-07-2005, 07:36 PM
SoCal Driver's Avatar
Don't let it go too long. The cam chain and pad under the valve cover is a ticking time bomb. When/if it breaks kiss $4,000 good by.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-08-2005, 06:56 AM
legion's Avatar
The car's in storage for the winter. It won't be out until March or April. I've got a basement that flooded that has to be addressed first.
-Chris
Old 02-08-2005, 07:19 AM
Same car, same action plan for this spring. I was wondering, do I need to automatically change the belt tensioner or do I leave it alone if it's OK. I understand that if you're getting the job done in a shop you might want to change everything you get your hands in but if you change the belt yourself and the tensioner looks OK??
Reading your respond got me a little bit scared, I was planning on doing the job my self (I rate my self 6 or 7 out of ten on mechanical abilities) just marking the crank and cam positions and putting them back were they were but some of you suggested to get it done at a speciality shop. Is that job really that complicated or is it just a little bit more than theT-belt I did on my 1981 Ford Escort 15 years ago??
Philippe
1987 944S , the more I drive it the more I love it.
Old 02-08-2005, 04:11 PM
If you do the work yourself, the only hassle is finding the time to do it all over again if you're lucky to catch it before it siezes.
I learned a lesson when I changed my cam and balance shaft belts. After about 3k miles , the tensioner pulley started making funny noises. The bearing started making noises, so I stopped driving the car and ordered a tensioner pulley from Zim's. Sure enough, the pulley bearing was about to go and I caught it before it siezed.
I will change the tensioner pulley every other 30k-mile belt replacement to be safe or every belt replacement if your pocket can afford it.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 02-08-2005, 04:39 PM
meister member
speedracing944's Avatar
I am expecting to host another timing belt tensioning party this spring near Madison WI. Maybe you can swing out to get your belts replaced here. I have a P9210 tool so we could check to make sure your automatic tensioner is tensioning the belt correctly.
Does the S use the same flywheel lock as the regular 944? What tools are unique to the S for a belt job?
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 02-08-2005, 05:27 PM
Speedy, that is what I like to hear. I missed your last timing belt party because I was busy that weekend. I was planning on doing it over my winter break, but ended up getting screwed over on my parts... long story. I did end up getting the wrenches, fly wheel lock, etc that is needed to do the job though. I was thinking of making a long weekend for myself here in the next couple weeks and doing it then, but if you are thinking about having a tbelt party soon I might just hold off.
Nate
'84 944, '05 GTO
Old 02-08-2005, 06:49 PM
AFJuvat's Avatar
Belts, cap, and rotor shuoldn't run you more than about $400 - $500.
Add about $100 more if you need tensioners and rollers.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 02-08-2005, 06:51 PM
a.n.other's Avatar
These cars are no more difficult to work on than any other car, so if you can work on an 81 Escort you'll be fine. You do need a special flywheel lock if you are changing the crankshaft oil seal, otherwise you will be ok setting it all to TDC (there are marks already on the cam gear and flywheel so you can line it up again afterwards) . Do it yourself and you'll save $$$ in no time - and you'll know the job has be done right.
Andy
Lowered '84 944 no longer smokin!
Lowered, adjustable KONI shocks, APE chip, K&N panel filter, Strut tower brace, Blue Fuchs (+ anything else i've not discovered yet!)
http://photos.yahoo.com/shineyblue944
Old 02-08-2005, 08:01 PM
Thanks for the invite for the T-belt tensioning party but I'm not sure if I thrust my 944 enough for a drive that long, maybe another year.
Philippe
Old 02-11-2005, 01:18 PM
