Porsche Crest Overheating: Please Help - AX in 7 days!!
I've had '83 944 (w/ 70k orig mi) for a month. Its never shown temp over 1/2 guage and PO was a good maintainer.
Yesterday the temp guage pegged, (under cool normal driving conditions) and coolant boiled.
I read up on bleeding the system (thread on this site) and did so 4 times using the "hose squeeze" method and the "blow through the drain tube" method.
Once the car reaches op temp. it rapidly (less than 2 min) goes from normal to overheating.
The upper and lower hoses both feel hot. So I am assuming I am getting "flow".
Once the car starts to overheat, coolant flows backward through the overflow tank and out of the overflow tube. This evacuates around a quart and more air enters the system.
Water pump is updated version with 18k miles on it, buT 13 years old.
Thermostat condition unknown and my next step of investigation; but my ASSUMPTION is since both upper and lower hoses and radiator are hot, that the thermostat is opening.
The heater works properly and blows hot air.
Water pump is not seeping and not making noise. I tried squeezing the upper hose to feel "surge" but could not really tell.
There is not water, bubbles or emulsification in the motor oil; no white smoke from the exhaust or on startup.
I'd really appreciate any help on diagnosing this. Thanks!!
Hank
81 911SC
Old 02-19-2005, 10:49 AM
Send a message via AIM to Trevor
Are the fans kicking on? The water pump sounds VERY old, when was the last time the belt was done?
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 02-19-2005, 11:02 AM
Thermostat might not be opening enough. I had one of my cars do this to me. Is the hose on the intake side of the radiator hotter than the one on the exhaust side? No temperature drop implies no cooling between - ie plugged radiator.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 02-19-2005, 12:13 PM
Your radiator cooling fan may not be running.
It should kick on at 92C, between middle and third line on the temp gauge.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 02-19-2005, 12:35 PM
Gents, thanks for the initial feedback.
The top hose feels hotter than the bottom hose, but they are both hot.
The left engine fan is cutting on, not sure about the right.
The car just had a pre-purchase inspection, belts look new, and did not merit comment in PP insp.
Radiator is 10 years old; supposedly a "turbo's" radiator.
My plan is to pull the thermostat out tomorrow morning check it in hot water on the stove and see how the car runs sans thermostat.
Any other advice out there?
Hank
Hank
81 911SC
Old 02-19-2005, 06:54 PM
AFJuvat's Avatar
Sounds like you have a bad thermostat
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 02-19-2005, 07:04 PM
I have a related question. The driver side rad. fan comes on, but even at very hot (siting and idling in stop and go traffic) the pass. side NEVER comes on. Im thinking fan relay maybe??
Old 02-20-2005, 12:32 PM
It's only supposed to come on when you turn on the A/C.
1983 944 with S2 motor, trans, suspension and exterior -- crunched parts car
1987 944 -- soon to be 1987 944S2
Old 02-20-2005, 04:01 PM
It comes on without the AC being on, of course, it is also AC regulated too. For the early dash 944 you will need a new relay.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 02-20-2005, 06:44 PM
