auh auh is offline
auh's Avatar
Send a message via AIM to auh
converting DMEs
What is involved in converting from a early DME to a late DME?
1974 914 1.8 Sold...
1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!!
1990 Nissan 240sx fastback aka Japanese 944
Old 03-10-2005, 12:05 AM
Can it even be done? I'm not so sure . . .
Old 03-10-2005, 02:20 AM
with a 86 or 87 DME - the AFM and Idle Stableizer Valve should also be changed. because the 88 & 89 had different comp ratio, I think using that DME/chip would not help you pass a smog test unless you changed the pistons too.
Tom
Early '85 944
Old 03-10-2005, 03:14 AM
Used & Abused
Yes you can.
You wont have to add an idle stabilizer valve but you'll need a later AFM (different voltages and flow curves). It's literally plug and play.
The plug-ins are the same for both the DME and AFM.
I've read the AFM must be the same year as the DME used as there were changes through time but that info was debunked by Frwilk.
I changed out mine with an 87, 944 and didn't need the stabilizer.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 03-10-2005, 04:25 AM
Cool, does the new DME take care of the early shudder?
Old 03-10-2005, 04:56 AM
SoCal Driver's Avatar
You can't use the later idle control vavle (stabilizer) with out replacing the DME to engine wire harness. You can use the DME with the later AFS.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-10-2005, 09:25 AM
"Cool, does the new DME take care of the early shudder?"
Yes, the code in the later DME removes the shutter. The reason you have to match the DME and AFM is that the early AFM is 0-8v and works only with the early DME. Conversely, the late AFM is 0-5v and works only with the late DME.
Many 944-spec racers swap to the late DME/AFM combo to make use of the plug-in chip socket.
Old 03-10-2005, 11:20 AM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
There is an extra sensor that the late DME used that can cause an irratic idle on the early engine since the early cars didn't have it from what I've read.
Have you used a late AFM and DME on an early car without modifying the wiring harness and had it work okay?
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 03-10-2005, 12:47 PM
Which extra sensor is that?
The DME/AFS combo is swaped out all the time.
Old 03-10-2005, 07:34 PM
hall sensor on the distributor?
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 03-11-2005, 03:18 AM
that's only on the 16v
Tom
Early '85 944
Old 03-11-2005, 06:36 AM
And it's on the back side of the cam gear.
Also there are two knock sensors in the 16 valves. And their idle control valve works in a different way than the others.
Old 03-11-2005, 07:31 AM
What does AFM stand for?
Old 03-11-2005, 07:57 AM
Porsche lists the device as an AFS; Air Flow Sensor. Others have taken to calling it an Air Flow Meter. As it does not intentionally restrict the air flow into the throttle body it is a sensor and not a meter. This unit also has a temp sensor for the incoming air.
Old 03-11-2005, 09:00 AM
Rmills944's Avatar
the Idle Control Valve is what I was thinking of. Is that only on the 16V cars?
Ryan
Old 03-11-2005, 12:00 PM
All of the 944's have an idle bypass for cold start. The early 944's are electrically heated to cause a bi-metalic spring to close of the opeing.
The later 944's have an active valve where the DME controls the opening. There are two kinds of these; one is bi directional the other (16 valves) is single direction with a spring to return it to open.
Old 03-11-2005, 04:43 PM
