what size allen wrench trans
what size allen wrench do i need to buy to remove the drain & fill plugs on my trans axle.
83 944 5sp thanks!
83 944....bye bye 85.5 euro spec 944, 5sp (she's gone.... ![]() 74 914...hasta LA Vista baby 87 924s....don't let the door hit ya 68 912.......see ya! |
17mm
Get one for a socket wrench, that will fit a torque wrench if you can.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
I think the trans oil drain plug torque is 17 ft lb.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit |
thanks! done.
And, of course, remove the fill plug first, so that you don't end up with a dry trans if you can't remove the fill plug...
gb
Good luck, George Beuselinck |
I took a old spare wheel bolt (17mm) from the 924 and welded it into a cheap 1/2 drive socket.
Rick 99 996C4 06 525XI 87 944S - Sold 77 924 - Sold |
I WOULD HAVE PREFERRED THAT, S&K HIT ME UP FR$22 FOR THE 1\2" DR SOCKET
