Driver
Re-installing lugs
Hi everyone,
I removed the lugs from my front hubs before sending the hubs out to be plastic-bead blasted.
I have the hubs back and need to get the lugs back in (they improve the ride a great deal!)
I have gotten two of the lugs back in using a hammer, but I have caused two or three very slight dings in the hubs.
I believe it is only a matter of time before I whack something really hard.
Is there an easier method for this and/or is this something a mechanic can do for me easily?
Thanks,
GHEN
'87 944
Old 05-08-2005, 02:08 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
do you mean the studs the lugs go on? if so just take them to a shop with a press and have them pressed in... or go to harbor freight and but a press, press them in and then return it and say it didnt work for what you wanted it to do.
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 05-08-2005, 04:07 PM
Or, get yourself a large vise and a deep 1 inch socket. Put the socket over the threads and use the vise to press the stud into the hub.
gb
Good luck, George Beuselinck
Old 05-08-2005, 06:00 PM
