AT Filter Change Need Advice
I need some advice on changing the Trans filers and gasket on my 944. Anyone here ever change one on an auto 944 ?
72 914 Sold
84 944 Sold
85.5 944 Sold
78 924 (first car) RIP
Old 05-19-2005, 07:15 PM
SoCal Driver's Avatar
AAMCO.
Same autotrans as other German cars; Audi and VW. Service should be the same.
Think I have a manual on the early 924 auto trans.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-19-2005, 10:36 PM
livewirevoodoo's Avatar
filter costs around $20. completely empty, the trans holds around 6 qts. of fluid. dropping the pan and draining from there i believe is around 2.5 quarts. drain when the tranny is warm.
filter install is the reverse of removal.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 05-19-2005, 10:59 PM
