Put in a new DME relay, still having problems
Early '85 944, fuel pump is not working, no spark either. Also, the windshield wipers are on and I cannot turn them off. I put a new DME relay in and had the fuel pump tested, and it seemed to work. Yet these problems persist, is there a way to test the computer? Any suggestions?
early '85 944 -project car, sort of works.
Old 05-22-2005, 05:42 PM
Send a message via AIM to michaelathome Send a message via Yahoo to michaelathome
I know that this may sound silly but have you looked to make sure that the timing belt it not broken or slipping?
Make sure that the rotor is turning.
Michael
Old 05-22-2005, 06:07 PM
Re: Put in a new DME relay, still having problems
Originally posted by qawse
Early '85 944, fuel pump is not working, no spark either .... I put a new DME relay in and had the fuel pump tested, and it seemed to work. Yet these problems persist, is there a way to test the computer? Any suggestions?
Check the crankshaft reference sensors, if one of them is bad or out of adjustment the DME Relay will NOT energize the fuel pump.
Mark
'86 944NA
'10 VW Golf 2.5 5sp
'99 BMW 540i Sport Wagon
Old 05-23-2005, 07:02 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
test your fuel pump and be sure that it actually works:
fuel pump working, but not
SoCal Driver
You can jump it to test with a jumper between the #2 and #3 fuse on the 8 fuse panel. Count from the drivers door.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 05-23-2005, 07:33 PM
earlr85944's Avatar
try pulling the intermittent relay to get the wipers to shut off, they will still work when selected to the fully on position, just a temp\perm "fix".
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 05-23-2005, 08:23 PM
Bradman951's Avatar
Send a message via AIM to Bradman951
Hey qawse, I just purchaised a 951 that wasn't running and had wipers that never stopped. I found that there was a connector near the DME that was not connected which was necessary to turn my wipers off. I have not yet gotten the car running so I am not sure if the wipers and no-start are related, but I did fix my wipers, right mirror and window! It is a two-sided rectangular harness... good luck!
'87 951
'88 951 not running... yet
'03 A4 Avant 3.0
'98 Volvo S70
Lazy thoroughbred
Old 07-27-2005, 03:57 PM
SoCal Driver's Avatar
Huh?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-27-2005, 04:07 PM
