Need Last Minute Help!!!
I just changed my front pads and now my pedal is very spoungy. My uncle helped me and he looked under the car while I pumped the brake pedal and no fluid was leaking. At one point I did open the reseviour to try to releave presure and forgot it was open when I first pumped the pedal. Could that have let air in the system?
I need these brakes working by tomorrow so I can make it to Effingham. PLEASE HELP!
1974 914 1.8 Sold... 1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!! 1990 Nissan 240sx fastback aka Japanese 944 |
Air.
You don't need to open the bleeder on the cylinders to retract the pistion. A large screwdrive used as a lever can coax the piston back. You need to bleed them.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Ok thanks, but jw how did air get in the system? I didn't open the bleeders, just the brake fluid tank in the engine bay
meister member
go out and drive the car to seat the pads against the rotors. Fresh pads on rotors will give you a spongy feeling until they conform to the shape of the rotors. I usually do a 20 mile loop which includes lots of braking and near the end I do a couple high speed threshold braking stops just to make sure.
bleed the system just to be sure. In autocross, they require a brake bleed before each event. Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) Last edited by speedracing944; 06-10-2005 at 04:13 AM.. |
ok, I was thinking the pads just needed to be seated, thanks
Speedy, you gonna be at funfest?
meister member
I would love to but I have a graduation party to go to. I thought about skipping out but there is no way to make it happen. I am going to 944Fest on July 16th. Are you? Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
just taking the cap off isn't/wasn't the problem unless the brake fluid got too low in the reservoir, you'll have air in the system.
when i do pads, i pump the pedal a few times so the pistons are where they should be in relation to the rotor and the pedal should be firm not spongy. the spongy feel won't go away by driving/seating the pads to the rotor.
87 951, K27/6, Almond Beige, 17" Turbotwist 87 944S, alpine white, 5sp died a violent death 84 944, silver/brown, auto, gone but not forgotten "may the force be with you" Last edited by bearone2; 06-10-2005 at 04:57 PM.. |
Actually seating the pads did make the spongy go away
meister member
good to hear. How was fun fest?
