meister member
speedracing944's Avatar
Need help sorting out logistics for a carbureted 944S
Howdy all,
I recently purchased a 87 944S which had an engine fire. The fire burnt up the entire wiring harness along with the MAF and all the sensors and fuel injectors. I visited the Porsche dealership and inquired about a new wiring harness. The technician laughed and said it was $1500, but.... There isn't one showing in Porsches inventory anywhere in the world. OUCH!
One option I am exploring in order to put it back on the road is to do a carbureter conversion. I want to go with 4 40mm Mikuni carbs. One mounted to each cylinder. From my research the 4 40mm carbs could support an engine churning about 250 HP. What I need help with is what kind of issues will I be running into as far as the electronics are concerned. I would still like to retain the stock ignition system along with the knock sensors. I understand I will need to do something about the fuel pressure since the carbs are designed to run at a much lower pressure than our fuel injection system normally runs at. I still plan to use a O2 sensor for tunning but I understand the sensor wouldn't control anything.
I feel confident the conversion can be done since there are many 911 owners who have done the conversion to PMO or Webers. They also report much better throttle response and much increase in HP.
Thank you,
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 06-11-2005, 11:22 AM
Just go to a Porsche wrecking yard and buy the correct parts, install and it's done. Or spend hours trying to make something work that won't.
911 carb conversions are completely different and have no features to compare.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 06-11-2005, 12:56 PM
least common denominator
scottmandue's Avatar
I have seen a 944 with weber sidedrafts, however it was a race (track) car so I don't know if it is legal or practical for street use. However someone may sell a kit for the conversion.
As Brit said probably easier to find a 944S that has been in an accident, or better yet blown the timing belt (broke belt=944S head ruined=big$$$=very motivated seller) but the fuel injection system should not be damaged from a belt failure (I think).
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 06-11-2005, 01:48 PM
We have everything in stock to make your 944S run again, without having to reinvent the wheel with carburetors...
Call us monday for a quote...
gb
Good luck, George Beuselinck
Old 06-11-2005, 05:58 PM
fast924S's Avatar
Send a message via AIM to fast924S
Why would you keep the knock sensor?? Its not gonna do anything if there isnt a DME. Your also gonna hve to do something about the igntion setup, then have fun tuning those 4 carbs. HP wise a good tuned FI car will run better and smoother, with better fuel economy and equal or better HP then a carb. Personaly I hate carbs, sure it work in the 50's but I think Fuel injection is way better.
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 06-12-2005, 10:44 PM
Burn the fire.
Brando's Avatar
fast924s... it depends on the quality of fuel injection,
I do agree with you, FI is better than carbs (by today's standards).
and you'll never pass smog with carbs.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 06-13-2005, 11:51 AM
fast924S's Avatar
Brando that is correct I hate CIS
Old 06-13-2005, 01:12 PM
Burn the fire.
Brando's Avatar
Aww... CIS works great. It can cure cancer, predict the future, even walk on water.
Well, in the perfect world where it works right.
Old 06-13-2005, 01:42 PM
meister member
Thanks for all the input guys. For now I am going to continue pulling the motor in order to repaint the engine bay. I think the carbs would be a realistic option and if they are tuned correctly they can deliver close to the same emissions output. BTW there is no such thing as emissions testing where I live.
Old 06-17-2005, 07:31 PM
