PhillysMostWntd's Avatar
Send a message via AIM to PhillysMostWntd
DME Relay not the problem... WHAT!?!
ok i got my new dme (had the 993 part number, but they are interchangable) put it in, car starts fine, drive it for a few hours, go to work, go to lunch, it works fine, come back, at 10 im coming home, and it doesnt start, i sit and try about 3 times, nothing, so just for the hell of it i put in my almighty 3 legged jumper dme, and it starts fine, i drive home, park it, and put the new dme back in, starts right up. any one have any idea what it might be? im thinking along the lines of a bad fuel pump, or a bad connection, but where is the pump located so i can take a look?
1984 Porsche 944 - down for the count, may be rebuilt
1999 Civic ex coupe - Turbocharged fun/Daily Driver
Old 06-16-2005, 11:13 AM
Zero10's Avatar
Send a message via ICQ to Zero10
I would try the jumper for a while, see if the problem re-occurs with the jumper in place. Or, once it starts with the jumper, try popping the relay back in. Perhaps the problem lies within the DME?...
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 06-16-2005, 01:35 PM
yeah im so confused, ive been driving around for about 2 hours today with the new DME and everything is going fine, dont know whats up
Old 06-16-2005, 01:46 PM
Custom User Title
Dave L's Avatar
I asked my mechanic about the DME relays and how long they last. He told me that some times a few years, some times a few hours. It it possible that you purchased a bad relay.
Old 06-16-2005, 07:12 PM
SoCal Driver's Avatar
Check the socket where the relay plugs in. Could be a loose wire or even a bad receiver for the pins on the relay. Your jumper may have oversize pins.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-16-2005, 08:25 PM
everything has been working fine today (before it got stuck in 4th) but how probable do you think it is that its a bad relay? im not sure what i should do, exchange it or keep it and see what happens
Old 06-16-2005, 09:28 PM
pokey's Avatar
Send a message via AIM to pokey
If it does it again, try tapping on the relay with your fingertip. If tat doesn't work, try a twelve pound sledge hammer.
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 06-17-2005, 05:17 PM
lmao pokey, ill have to try that next time, makes a good saying
"what does not function must be destroyed"
Old 06-17-2005, 07:55 PM
