more problems
Having not driven my 924 for some time due to my 944, with summer here i finally got her road legal today.Thing is the steering (not power steering) doesn't seem to be as it used to.At times it's quite hard to turn the steering wheel - especially on taking a sharp corner, but this afternoon i pulled into a parking space doing a full right hand lock and there was a bad clicking noise which appeared to be coming through the steering wheel itself - what's the likely problem?could it be the ball joints seizing?
1989 guardsred 944s2 cabriolet,
1983 metallic claret 924 lux (sold)
Old 06-20-2005, 07:01 AM
SoCal Driver's Avatar
The steering link u-joints are seizing up. Not an uncommon effect of leaving the older 924's sitting for a length of time.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-20-2005, 07:41 AM
A bit of grease is called for then? or does it mean they're probably knackered?
Old 06-20-2005, 08:28 AM
No way to grease them. Have to replace the link. Someone on your side of the pond found a new or rebuilt for about $110 USD recently. Might have been a serviceman in Germany.
Old 06-20-2005, 08:43 AM
Problem solved - there was a what looks like a "home-made" earth wire wrapped fairly tight around the steering column which was tightening up
on turns.I've took it off - not sure what it was for - but steering is fine now.Strange!
Old 06-20-2005, 10:55 AM
Try your horn.
Old 06-20-2005, 01:51 PM
