944 Transmission problems please help!!!
Ok when im driving my 1986 porsche 944 i can shift up or down into any gear except 2nd. I cannot downshift into second gear untill i have come to a rolling stop. I dont know what the problem is. Someone PLEase help!!! THX alot
You probably can actually get in to second if you match engine revs but that isn't a long term solution.
As it was explained to me each gear except reverse has its own synchro which is a bronze (or some softer metal) cone like item with nubs on it. Wear the nubs off and it is a goner and won't work anymore. Since you can shift into second on a roll your shift linkage is OK and the reason you can get it in is that on a roll your drive shaft at idle rotation is probably pretty close to second gear's rotation speed. So you may have to pull the transaxle out, take it apart and replace the synchro. I have no idea how tough it is to crack open the transmission and what special tools you would need to do the synchro. But I do know you can buy new synchros. The transmission gurus can explain this better and confirm the likelyhood of the above. |
It probably is a synchro, but damn, it really is not easy. The yellow arrows are pointing to synchros. In order to replace, one needs a press and a few other special tools, plus the synchros. For the cost of a used 944 trans ($400-$600 if you shop around), you are just better off buying one and swapping it out in a couple of hours.
1985.5 944 Club Sport My P-caronline Profile "A good time to keep your mouth shut is when you're in deep water. "-- Sidney Goff |
Ornery Bastard
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
It must be all of the HP my car has........
Ornery Bastard
Sounds like you have a bad syncro, Its a big project to open the tranny and you will need a good book and special tools to do it, plus if your paying a shop to do it its big money, Your better off getting a used tranny for like $500
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
Thx for all you guys help. No i do all my own work myself and have some special tools but i think it would be easier to get a new transmission. Do you guys know where i could get one? I have looked around and can only find rebult ones for about 1200$ Im looking for a price around 5-650$ Please help i just rebult my whole engine and want this out of the way/ THX Alot
Check the for sale section of this forum.
Still looking for the right deal on another P-car 1968 BMW 1600 2 liter 1956 Ford F250 1955 BMW R69 1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...) |
speaking of transmissions...anybody know about the plastic plug at the rear of the manual trans? Mine looks like it's leaking oil there and I got a new one. Does it require some sort of sealant gook?
Thanks,
Gene ____________ '86 944 NA '88 Citroën 2CV |
i cant find a used poersche trans anywhere for under 1000$ Can someone help me?
Try over at rennlist, in the classifides there is a bunch of guys selling parts, ask around Im sure you will find one
http://www.rennlist.com/ads/ Also here is a e-mail address of a guy parting out a 84 944 and he has a tranny fastjackracing@earthlink.net
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership Last edited by fast924S; 06-26-2005 at 07:29 PM.. |
yeah thx but i dont think wthe 84 trans will fit being that it doesnt have the electronic speedometer hookup. Am i right?
I'm pretty sure it will fit as even 924's will, but you do lose the speedo.
Im not sure, My 87 924S tranny has a block off plug where the speedo would be, When I dropped in the 85.5944 tranny it had the speedo in the tranny and I just unscrewd it and put the plug in it. So Im not sure if the tranny still has the speedo gear in it put I do know that all the housings have the whole for the speedo
Oh, I was talking early pre- 85.5 924/31 transmissions, not the S. All should work as far as dirve train function, it is the speedo pickup that may be a problem. With the exception of eary ones that had a speedo cable driven off the front wheel I thought all were electronic off the transaxle.
so i guess theres no point in buying an early trans i kinda need the speedo. I wonder if theres a way to make it work with an electronic speedometet
Location: Sometimes Sacramento, Most of the time Concord, CA
hey tifosiman, you have a PM
1987 944 Naturally Animalistic "If you make the same mistake twice, doesn't that make a total of three mistakes?" |
I've got some gears from my '95 968 that I'm selling.
If you're interested in 3rd-6th gears, E-mail me and we can discuss it. Jason www.flamthrowr@aol.com
Jason Judd |
Watch ebay, there are always 944 N/A transaxles on there for around the $400-$600 range. Of course, there would be no guarantee on the longevity of those used ones............ Quote:
