princetonprep17's Avatar
Did replacing your vacuum lines really make that much of a diff?
The title pretty much sums it up. I've read that replacing the vacuum lines on the 44s can make a world of difference. Is this really the case? The lines are 21 years old now and I'm considering replacing them relatively soon.
Old 08-18-2005, 03:13 PM
Ornery Bastard
So much of the FI is driven by vacuum readings, it can make a huge difference.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 08-18-2005, 03:53 PM
Gotcha, FI is uncharted waters for me as I'm used to the good ol' carb. cars. I think I might just go ahead and order the hoses now. Approx how much of each size do I need to get to do my entire 84? TIA
Old 08-18-2005, 04:22 PM
If you don't have a single leak in your system then it wont do anything. If you have air leaking then it will make a world of difference. If you have 20 years on the OG lines then I am guessing it is a good idea.
1987 944S
2000 passat 1.8T wagon
Old 08-18-2005, 05:20 PM
gtroth's Avatar
I would measure your vacuum first. I think ~18 inHg at idle is good. I got 13 inHg and car runs beautifully though - most of the time. Idle drops perilously low every now and then and has stalled twice last winter. That's my ISV, I think. But as long as I'm under the intake manifold I'll replace every vacuum line and hose I can see.
1995 993C4 guards red
1988 944S alpine white
Old 08-18-2005, 05:33 PM
What are some symptoms that vacuum loss would cause? Poor idle? Poor throttle?
Old 08-18-2005, 05:34 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
The lines for the damper, fpr, tb, all are 4mm lines using 3 way 4mm tees. 20 ft will do. 5-6, 3 way tees
The hoses in the AFM/ ISV and etc are varied sizes from 10mm to apprx 13mm ID. 1 each and are molded hoses. Look at the hoses for proper bends and lengths.
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 08-19-2005, 04:34 AM
I just replaced all my vacuum lines. before she was missing at around 4500 rpm, rough idle, poor gas mileage. I also changed plugs,wires, cap & rotor. Now thanks to the guys in here for their help. She runs great now.
89 944 na Dove Blue Metalic
2000 chevy silverado
2000 chevy 454 dually black
79 GMC short bed 4x4
4 quarter horses
89 acura legend GS sedan
Old 08-19-2005, 05:09 AM
livewirevoodoo's Avatar
Looking for a little clarifcation here please. Can i replace both the soft rubber connectors and hard vaccuum lines with a 1 piece run of silicone hosing? I'm referring to all the small 4mm tubing.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 08-19-2005, 07:36 AM
I changed all my lines with vacuum lines from the local parts house. I do not know if the diameter of the line is critical or not. Mine seems to run fine though.
4 quarter horses
Old 08-19-2005, 08:26 AM
924Sman's Avatar
Yes....The hard plastic is to help with heat created so the hard plastic lines were installed to prevent the hoses from melting as they rest on hot metal particularly under the intake.
I ran all silicone and zip tied them up and away from any contact with hot metal. What you are dealing with are a bunch of rubber elbows attached to plastic tubing. All you need to do is cut new line to replace the plastic. I found that most of the cracks were in the rubber 3 way connectors(tees).
Old 08-19-2005, 08:56 AM
