Angry Shaking??!?!
Sorry.. just to clarify..
1. Does the car still run after the flex disk goes? I ask because..
2. Whenever I stop the car the car shakes a little but it's perfectly fine when I am driving..
So I guess my question is.. how exactly do you know when the flex disk goes? Is there a simply place to check on the car for a non-mechanic, or is the shaking enough to indicate that the flex disk has gone?
I have also noticed my shifter gets very hot after it is driven for a while..
Thanks!
Old 09-15-2005, 04:39 PM
hey...i just got the flex disk in today!! THE RIDE IS SO SMOOTH
i realized that
1) u kno ur flex disk is about to go if u feel vibrations at stops. I thought it was the motor mounts, but once i got hte new disk in, no vibrations. this is probably one sign of a bad flex disk.
2) once the flex disk breaks, u must replace it right away, yes it will run. but at stops u will hear metal clashing against metal (loss of rubber part). then, when u accelerate, if u accerlate too hard, u feel grinding and the car shakes..this was a very bad experience.
yes its pricy, but the outcome is outstanding
84' 944
Old 09-15-2005, 07:29 PM
livewirevoodoo's Avatar
Take a peek under your shift boot. There should (or was, as new) a rubber shift boot underneath that is used as a sound deadener/heat insulator....
Back to the flex disc....
Might be hard to describe the vibrations at stops, but can ya, possibly? Could you tell where they originate from (front/mid/back of car?)
I get a studder/grabbing sorta sensation, only while breaking (not a rolling stop or stopped, mind you, just breaking), mid-back of car, from which my mechanic says is the e-brake sticking.
Not that I don't trust his judgement... But all this talk of flex discs makes me perspire slightly.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 09-15-2005, 08:45 PM
well first off...i thought flex disks only came on autos?
but if they come on manual trannys too, heres what happened to me
my assumption is that when the car is in motion, the flex disk has angular momentum, which keeps it running smooth. however, once u slow down, and slow down that momentum, the disk becomes a lil more "off" if u will. im not sure about braking, but i kno that when i stopped, the entire car would shake (flex disk directly under shifter). the way my mechanic stated the job of the flex disk is as follows: it buffers the power from the engin onto the tranny. so if the disk is about to die, it'll vibrate more and more.
take my advice, switch out the flex disk if u are uncertain (be away that engine shaking is also due to engine mounts). i drove on the broken disk for all but 15 min, and shards of rubber crap got stuck in very very very bad places...took the poor guy 3 weeks to take out. an ounce of protection will bring a pound of cure...
thats my 2 cents
84' 944
Old 09-15-2005, 09:07 PM
ya... see my sig... 3 speeder here.
im not sure about braking, but i kno that when i stopped, the entire car would shake (flex disk directly under shifter).........
(be away that engine shaking is also due to engine mounts). [/B]
Thanks for the clarification... I know my mounts are pretty shot, got that planned for mid-october after I get back from san fran... Was hoping to not have to deal with a flex disc for a while. From what you describe I think my mechanic might be spot-on about the e-brakes.
''87 944na 85k
Old 09-15-2005, 09:15 PM
Chris_924s's Avatar
Mine let go in the driveway about 6 years ago, backing out of the garage. went into Drive and terrible vibration... no go forward.
check the inspection hole by the started for chunks of rubber..
IIRC I paid 650$ for a new one at Vertex.
My old wrench charged me for 22 hours of labor. I suspect he screwed up my TT bearing as well. Took him 3 weeks to get my car back to me.
been doing my own work ever since
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 09-16-2005, 04:44 AM
wow...my mechanic charged 8 hours but took 3 weeks too...he said he's glad to get my car outta the shop haha.
its good to check that hold under teh flex disk once in a while, check on the rubber. unfortunately, with all rubber parts, they fail. try to change it out before it does any worse damage :-\.
84' 944
Old 09-16-2005, 08:57 PM
Inspection Hole Location?
Can you please tell me where the inspection hole is? (by the starter?) Where is that?
Sorry to be so stupid.. but where exactly do I look on my car???
I've had the vibration at stop for over a year now.. no issues with using my shifter in all gears, and no issues with the car running.. and it's not the motor mounts cause they were recently replaced.
Thank-you.
Old 09-18-2005, 08:32 PM
driver's side, mid-front of the car, in front of the cat. hole about the size of the bottom of a pill bottle. ( I believe #20 )
Ok... my follow up question is: I looked inside that sucker. Nothing notable. All I could really make out was #23 in the picture . What am I looking at here?
''87 944na 85k
Old 09-18-2005, 08:45 PM
if memory serves me right, u'd be looking at the part where the flex disk attaches to the driveshaft. if its broken, u will see shards of rubber all in there, and parts of metal (if its really bad).
and dave...my car vibrated for a long time too, and i thought it was normal cuz i changed the motor mounts...guess not :-\
84' 944
Old 09-18-2005, 09:13 PM
ldl ldl is offline
ldl's Avatar
Usually, if the flex disc was shot, you'd see small chunks of rubber; especially if you heard a racket of clanking from the front while idling...
I had mine done roughly two years back. Everytime I think about it, a small tear rolls down my cheak due to how that repair made my wallet bend over as it had it's way with it.
Nevertheless, to be specific, where's your clanking/rattling coming from? (Front/Back)
I ask due to the fact that mine is currently making noise from the back. It's a light rattling, not like the clanking that came from the from when my flex disc went. However, right before I stopped driving it, along with the light rattling from the rear, it started to idle roughly, and the whole car would literally shake when I hit 2500 RPMs...
Any thoughts?
85.0 944 Automatic
^ Bending my wallet over at every possible moment.
Old 09-18-2005, 09:25 PM
Porsche Crest
1/2 way through the Flex Damper replacement now. I ran mine periodically for 6 months before it completely gave up the ghost. However, the rattle, rattle, rattle at stop lights was quite embarrassing.
If you have the Horrible Rattle, Rattle, Rattle at idle but seems ok when driving and looking in the flywheel inspection hole finding bits of Rubber Dust or chunks and excessive vibration you can bet your last $1,200 it's the Flex Damper.
Once inside the guts of the bell housing, everything except the Damper was in good shape.
Hopefully, someone here can answer this question quite soon. What to I use as alignment marks on the Damper & Flywheel when reassembling?
A friend did this same job and it took him Four tries of trial & error until all 9 bolts fit. I really don't want to go through installation four times if I don't have to.
'84 944 NA Auto, '87 924 NA, '73 VW Bus, '97 VW Cabrio.... kinda like German Engineering
Old 07-15-2013, 10:14 AM
There is a notch in the in the flex disk that lines up with a line on the flywheel. There are also dowels that align the plate with the flywheel.
Old 07-15-2013, 01:18 PM
The Photos of the alignment marks are perfect....THANK YOU!!!!
Old 07-15-2013, 01:29 PM
FLYGEEZER's Avatar
My 84 automatic with 133,000 miles 'blew' the first dampner at 120.000 miles and 25 years old. Replacement cost, with parts & labor ten years ago was around $1100.00. The bad part of the deal is.. the last disc made was in 1995. The NOS sitting on parts shelves around the planet are ALL getting old and we know how well the germans make rubber & plastic parts. Age causes bad things to happpen (cracks/seperation) . If I ever need another one ...I'll do the Ean 944online thing and get a standard flywheel and clutch (without a throwout bearing) and do it that way for a lot less money. My 944 doesn't get driven enough anymore, just shows, cars & coffee and PCA club events so I'm hopeful I'll never need another one. But who knows, time marches on and time is as bad as miles & usage.
Edgar
1984 Porsche 944 bone stock
1995 Mercedes E320 wagon
1970 Honda CB350 mint!!!
Old 07-16-2013, 10:39 AM
We'll after tonight or tomorrow I'll be Bona Fide as a Porsche Owner..... I'll have completed my First of hopefully very few Flex Damper Replacements. The Part I have is used, low miles, good condition, date stamp 1992. I took the precaution of soaking it in Marvel Mystery Oil prior to installation. Dad was a PhD Chemist with a speciality in Rubber Chemicals. Plastics & Rubber lose elasticity over time due to UV's, Oxidation and Evaporation, liberally applying certain oils (that soak into the rubber) will increase life. If the damper holds out a year I'll be happy, 5 years ecstatic. I wish someone would make one out of Polyurethane instead of rubber. If I have to do it again the car's getting switched to a 5 speed.
Old 07-16-2013, 01:14 PM
This is what I did to mine. I don't know when the disk was changed last, but the price of those flex disks have gotten expensive. I think the total cost of "used" parts to convert mine to clutch parts was about $150.
Old 07-16-2013, 01:26 PM
Okie Dokie, the '84 is reassembled Correctly, Flex Damper replaced!!! .... I just completed one of the hardest mechanical jobs I've ever done.....Bad News, she won't start.
I have pressure at the fuel rail
I don't hear the fuel pump
I don't have spark on the wires or coil wire
I didn't move or reposition the Sensor Mounting Block
I attempted start with Speed & Reference Sensors in both positions (swapped them in the event they were in the wrong positions)
The Flex Damper went out last October (12), it also wouldn't start then since the starter was binding up due to the flex damper. It's sat since then, battery disconnected, 1/2 tank of gas. It now has a FULL charge on the battery, all grounds are good as far as I can tell.
My thoughts are maybe the DME?
Thoughts, experiences, Suggestions PLEASE. It's an '84 NA Auto
Old 07-21-2013, 09:45 PM
Porsche Crest
NM..... I DID do everything right after all.....I checked the DME connection.....pulled it aft...CLICK.... instant start & RUN and w/ the new Flex Damper it's a DREAM to drive again....Thank You everyone for the assistance!!!
Old 07-21-2013, 10:58 PM
help me my damper plate just went in my n/a 88 944 what exactly do I need for keep it auto but avoid the hefty price of a damper please car is down and it is killing me not much time left here in upstate ny to drive it before the snow comes need links to the right parts and the exact order they go in
Old 08-31-2015, 04:37 PM
