Hey guys,
i have an automatic 944 84', and the flex-disk just broke..and the sound the car made was horrible. took it to the shop and they said it would take about 5 hours to fix. i wanted to kno where i could find this flex-disk part and if there are any good sites which would sell em cheaper. thanks
84' 944 |
try oklahoma foreign or parts heaven, they should have a flex plate.
1992 freightliner 1994 freightliner 1970 dodge challenger r/t se 1994 ford f-150 1984 porsche 944 1991 corvette z07 hopefully a 2008 dodge challenger |
out of curiosity, what did it sound like and were there any symptoms leading up to it?
have not experienced a flex disk failure, but would like to know what it is when it happens.
''87 944na 85k C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946 '94 Oldsmobile 88 Royale (winter beater) Its not what you drive, its what drives you. |
it was totally unexpected. no sound problems, nothing. it just happened, and u could feel ur car shake. i was going up hill, pushing it. plus i was driving it for a while on a hot day
. but yea, at a red light, you will heard a loud clanking sound, metal against metal. very loud and very annoying. i dont kno how you can tell if its about togo....especially because this is such a vital component. but yea, i guess im looking for $1k in repairs.
84' 944 |
Buy a new disk unless you can get a low milage used one. Todwick had one let go when he lived locally. Was a racket!!!
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
so i guess theres no way to tell
. this sucks..i start school next week..btw...not to change topics..but does anyone kno any good security systems for cheap? thanks
84' 944 |
Don't put a high dollar stereo in it. Pile lots of junk in the back and leave the cargo cover rolled up so it can be seen. Don't wash it. Put DeadHead stickers all over it.
HAHAHAH that'll cost close to nothing lol.
84' 944 |
Good luck on the shop only charging you 5 hours........
Alarm systems..cheapest is to pull the fuel pump relay out every time you park it..no cost. Letting an alarm shop work on...a good way to annoy the shop that will be working on the car afterwards.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
Or a hidden toggle that disables the fuel pump.
84' 944 |
Hope he noticed that the flex disc is on the engine, not what the torque convertor is bolted to....
Yeap. Bet he finds out and charges you more. If he's never done one before he's in for a surprize.
Hint: You have to unbolt the flex disk from the flywheel and the engine from the bell housing to get to the clip on the front of the drive shaft. That clip is between the disc and the engine.
yeah, the ‘flex plate’ (that the torque converter attaches to) rarely breaks.
but changing that disk (or rubber flex damper) on the flywheel is about the same amount of work as a new clutch. the part alone is about $700…plus what?... 8 - 10 hours labor minimum unless you do it yourself, you’re looking at about $2000 or more - easy many would say there are better ways to spend that money than to put it into a 22 year old slushbox
Tom Early '85 944 |
Then answer: Which to I have more of?
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
dampner
IF you are interested, I have a used one for sale. I took it out of my 88 that I converted to a 5-speed. It is in decent shape with some surface cracks starting to come in it, but it is solid. E-mail me and I can send you a couple of pics.
toddandcharity@peoplepc.com Thanks, Todd
86 944 daughters 88 944 step-sons 07 Ranger 4x4 I have tons of spare parts, let me know what you need. |
thanks for the offer todd, but i already started the job....man...he only charged me 8 hours, but he's put a total of 18+ hours trying to get some broken piece out of the other parts. its been a real headache let me tell u...btw
how did u change ur 88 to a 5 speed? is it hard?
84' 944 |
What broken piece? If he's never ever worked on an 944 let a lone an automatic 944 your're in trouible!!!
Read him my previous post where I describe the procedure to get to and remove the damper at the back of the engine. Further thoughts: Bet this is the sensors. Just remove the bracket sensors and all.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! Last edited by SoCal Driver; 09-07-2005 at 08:44 AM.. |
OK, after Hugh's post regarding the sensor bracket being broken...what's the betting that it won't start after repairs?
As I said, good luck on the shop only charging 5 hours....
Be afraid! Terribly Afraid!
