replacing front struts with new inserts
I am in the middle of replacing my old control arms in my 84 944 and decided to replace both front strut inserts with new boge turbo OE replacements. I have a spring compressor but noticed after removal from the car that the cap on the middle section of the shock must require some sort of special tool since it just has two notches in it. Took out my new inserts and they have preplacement caps. So does anyone know where to get a tool or any other ideas to get this cap off. Plus I noticed when I turn on the end nut on the strut upper side it just spins the shock shaft?
87 944
Old 08-27-2005, 08:09 AM
SoCal Driver's Avatar
Use a drift or punch to loosen/tighten the nut. Otherwise you need an adustable spanner. Search www.harborfreight.com
Or a pipe wrench.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-27-2005, 08:36 AM
They could be sealed struts, in which case the ones you have as replacements won't fit. Koni make a kit for those type of struts to go to adjustable,or look on Ebay or a wrecking yard for the threaded cap type. George at 944 Ecology would have some.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 08-27-2005, 10:02 AM
BananaClip's Avatar
Send a message via Yahoo to BananaClip
Yeah, I thought 84's had sealed struts. You do cartridges on the 85+.
keep the dream alive!
1988 944 NA (purple)
Old 08-27-2005, 10:13 AM
Did cartridges on my 83.
Old 08-27-2005, 11:53 AM
That Guy
Techno Duck's Avatar
Sealed struts are on the '86 944 Turbos and on all 944's from '87 and up.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 08-27-2005, 01:46 PM
86 struts I have are the same as the 83. Plus clips for the pad sensor wires.
Old 08-27-2005, 05:50 PM
These are not sealed struts, they come apart, tried a 14" pipe wrench with no luck. Guess I'll go get an adjustable spanner wrench.
87 944
Old 08-27-2005, 05:59 PM
Spray the heck out of them with wd-40 or PB Blaster.
Old 08-27-2005, 06:10 PM
