livewirevoodoo's Avatar
Cat Back Replacement Question
Looking at swapping out the abortion that is my cat back..
Looking at the PET, i notice a sealing ring between the catalyzer and the exhaust pipe.
Part # 94411120300
Does this need to get replaced when I do the exhaust or do i just reuse what I have?
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 10-11-2005, 05:04 PM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
I just reused mine. It's a hard ring - I had to chunk it out with a screwdriver, but it popped out in one piece and fit right on the SFR system.
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 10-12-2005, 07:45 AM
Cars & Coffee Killer
legion's Avatar
They do get old (and possibly corroded) over time and don't seal as well. Replace if corroded. Keep if not.
5 liters of VVT fury now
-Chris
Old 10-12-2005, 07:48 AM
That Guy
Techno Duck's Avatar
I reused the old one when i changed the cat-back on my car. It had a sizeable chunk missing out of the side. I would buy a replacement if yours leaks (which it probably will i think).
Getting those bolts loose for the catback flange were a *****...i broke all 3 off intentionally because the bolts were so badly corroded to the studs.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-12-2005, 08:52 AM
Rmills944's Avatar
I had a shop drop the exhaust to fix some stuff on the tranny and drop the torque tube about 2 weeks before I pulled off the exhaust on mine... it came off easy!
Oh, I also was using a lift and air tools at the Dodge dealer in town
Ryan
Old 10-12-2005, 11:32 AM
That Guy
Lucky, i was to lazy to bring the car to my fathers shop. I ended up getting the rear on ramps and using alot of brute force with open ended wrenches. I was surpised how heavy that stock exhaust was compared to the SFR unit. I had trouble supporting that exhaust with both hands, putting in the SFR with one hand as support was a breeze however.
Jon
Old 10-12-2005, 12:48 PM
Thanks guys. $6 piece from pelican. Thing I'll spend the couple of bucks (why stop now?).
''87 944na 85k
Old 10-12-2005, 06:17 PM
