Help with Vibration
I just got my 924S back from the shop where I had among other things the timing/balance belts changed. I now have a vibration that increases with RPMs.
The mechanic is claiming that it is a bad flywheel, but the vib was not there before the belt change. I'm thinking the balance shafts were not aligned correctly.
In the words of Bill O'Riely, "What say you".
S. Herald
NASA Engineer
1988 924S
Bought as a fix-up and sell,
but fell in love.
Old 10-12-2005, 03:19 AM
I imagine it is the timing belt. I do mine myself. Every now and then I'll misalign one - usually the lower one. It is not hard to do. There are marks on the plastic housing of the belt cover that should line up with a notch on each shaft drive pulley when the engine is at TDC.
Vibration is a high frequency one - twice engine speed.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 10-12-2005, 04:12 AM
Just thinking out loud
mattdavis11's Avatar
I'm pretty sure Lawrence meant the balance belt. The shafts probably are not aligned correctly. Remove the belt cover(s) both upper and lower, set the engine to TDC and check the marks as suggested.
91 FJ80
84 Ram Charger (now gone)
Old 10-12-2005, 08:01 AM
Yes, I did not type what I meant. It's the balance shaft belt. Sorry about that.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 10-12-2005, 08:05 AM
Where any front balance shaft seals replaced? if so, your mechanic may ahve gotten a pulley installed on the wrong keyslot.
Old 10-12-2005, 08:42 AM
No, no seals just the belts.
The mechanic is going to check balance shafts when it goes back tomorrow. I fragged the clutch this weekend.
You know I had her up to 130 mph and just knew she had 140 in her. Well she probably did but the rubber donut didn't. Ah well, I was wanting to put a spring centered clutch in anyway that donut had 100K miles on it.
S. Herald
NASA Engineer
1988 924S
but fell in love.
Old 10-12-2005, 01:01 PM
