Send a message via AIM to schnork
Weird whine front passenger side of engine
Hi, folks:
My '86 944 has developed a strange noise that I can best describe as sounding like a table saw (a sawblade spinning with no load, i.e., not cutting anything).
I've disconnected the power steering pump and ran the engine - the noise was still there.
I've examined all of the timing and balance shaft cogs and idlers behind the front cover - no problem there.
I've gone over the engine with a stethoscope, and the only time I hear this noise is when I touch the probe to the end of the oil filter. This is particularly wierd, since there are no moving parts that I'm aware of connected to the oil filter mount.
The sound is not present when the car is first started, but it seems to begin once the thermostat opens.
The only thing I can think of is that some kind of failure may be happening with the water pump. I replaced the water pump about 6 months ago with a rebuilt pump. Maybe I got a bad one.
Any ideas?
Larry
Larry
1986 944 Black (guarded by a 1998 Chow Chow, also Black)
Old 11-16-2005, 04:26 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
I was also thinking water pump. If it siezes, it's bad news as it likes to snap timing belts. Can you start it and listen to the pump by using a stethescope? Even better, pull the belts off and try turning the water pump by hand - you can usually tell if its bad bearings even by that.
Black Cars Matter
Old 11-16-2005, 05:07 PM
seaboltman's Avatar
i would put my money on you got a bad water pump
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 11-16-2005, 05:47 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Try the A/C.... you may see metal shavings...
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 11-16-2005, 05:55 PM
Don't rule anything out. These cars have a nasty habit of making noises that are far away from the real problem.
Might be a bit out there, but try engine braking on a hill. Put it in 2nd, keep off the gas, go 20 or so down a steep hill nearby. Is the noise worse? I'd wonder if it's a vacuum problem.
Check the pump first, though...you don't want that to fail, if it really is that.
Old 11-16-2005, 06:34 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
I had a very strange engine sound not too long ago, it ended up being that the gear that attaches the balance belt and serpentine belt to the alternator became cracked somehow. The noise was so bad that I thought I had a crack in the headers/exhaust.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 11-16-2005, 07:29 PM
Re: Weird whine front passenger side of engine
Originally posted by schnork
Hi, folks:
Any ideas?
Larry
I have a similar noise to what you describe on startup but it doesn't last very long and is quite intermittent - i too suspected the waterpump but it's only there for a short while and dissapears within a couple of minutes after starting.
Strangely the noise seemed to start just after i disconnected my ISV to clean with carb cleaner a short while back.
1989 guardsred 944s2 cabriolet,
1983 metallic claret 924 lux (sold)
Old 11-17-2005, 09:45 AM
