Marcelh's Avatar
Diff Fluid for Automatic
Does anyone know where the drain plug and fill for the rear diff is on a 924S or 944 Automatic????
The manual states there should be one but does not say or show where it is or what type of fluid??
Any help is appreciated.
Thanks,
Marcel
1997 Porsche Boxster Red
1993 Porsche 968 Red
1988 Porsche 944 Metallic Gray
1987 Porsche 924S Red
1987 Porsche 924S White
Old 11-22-2005, 06:43 AM
livewirevoodoo's Avatar
it is rear, driverside of the car, located on the tranny case. I believe it is either a 17mm or 21mm hex head used to gain access.
There is only a fill hole, no drain hole. Fluid must be pumped out to be refilled. I believe the spec calls for gear oil, 75-90W.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 11-22-2005, 06:48 AM
Eldorado's Avatar
i put 80w-90 in last time...
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 11-22-2005, 11:55 AM
I did too.
''87 944na 85k
Old 11-22-2005, 12:15 PM
theres a resevoir cap for the fluid...i just poured it into there and eventually it fills up
84' 944
Old 11-22-2005, 12:49 PM
The reservoir is ONLY for the automatic trans, not for the diff. The diff oil is seperated. If there is diff oil in the trans or tran oil in the diff, the oil seals in the main shaft have failed and the trans needs resealing.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 11-22-2005, 01:04 PM
Marcelh's Avatar
So does this mean you fill until it runs out?
Thanks again.
Marcel
Old 11-22-2005, 01:24 PM
Re: Diff Fluid for Automatic
Thanks again.
Marcel
Capacity is 1 liter. Rule of thumb is if you stick your finger in the hole you should be able to feel the gear oil without having to really reach for it.
When I first purchased car and did the diff. fluid, it was so dirty it was like mud. Took forever to pump it out, and I was sure i didnt get it all. So I filled to capacity, drove for a week, redrained (much easier to do this time) and refilled with fresh fluid. Car felt much more agile.
''87 944na 85k
Old 11-22-2005, 02:29 PM
Eldorado's Avatar
last oil change, i went to one of those drive through places... the guy came up to my window, and was like "sir... your diff. fluid is.... well, see the thing is....... it's GONE.."
lol - they topped it up for me on the spot.. good to go...
Kyle
Old 11-22-2005, 03:16 PM
Wow. The drive thru place checked the differential fluid?
''87 944na 85k
Old 11-22-2005, 05:32 PM
If the diff fluid is gone then the seals are leaking and it ran into the trans...common problem and fixable. Of course, this assumes that the levels were checked correctly and some sort fo diagnosis was done to see where the fluid went. Fluid doesn't just go and yet another reason to work with shops with PORSCHE experience.
Old 11-22-2005, 06:47 PM
