livewirevoodoo's Avatar
Wrong Throttle Return Spring?
Ordered & recieved a new throttle return spring as old one had a little slack in it.
After recieving spring, I realized I ordered 944-110-071-00. The 2nd part number listed in the PET was 944-110-071-01 (and had the comment "AUT" in the lefthand column). I'm assuming this denotes automatic, which is what I wanted.
Inspecting the 2 springs, both are same size, length, gauge, etc., with the only difference being that one end of the wire hook (the end connecting to the cam) is slightly longer on my older auto-specific spring.
I installed the new one with no adverse effects.
Should I be concerned at all to return it for correct part #?
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 12-06-2005, 05:12 PM
winter-hater club member
nynor's Avatar
nope.
"COOL PRIUS!" - Nobody Ever
Old 12-06-2005, 06:52 PM
Thanks. Only think i could think of was the spring snapping loose and being thrusted into WOT... lol
''87 944na 85k
Old 12-06-2005, 07:33 PM
fast924S's Avatar
Send a message via AIM to fast924S
I wouldnt worry about it, As Long as it seems to be installed ok and feels good then roll with it
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 12-06-2005, 08:50 PM
