Fuse #29 keeps blowing causing climate control inop
I keep blowing fuse #29 which in turn causes the climate control unit to go inop. Any ideas on where to start?
Old 12-16-2005, 08:12 AM
That Guy
Techno Duck's Avatar
Does the fuse blow imeditatley after you replace it?
You will need to start going through everything that fuse #29 is related to in order to see where your short is. Is your car an early or late model?
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-16-2005, 08:14 AM
It takes a little while before it blows (it will function normally for a little while). Does anyone know what that fuse serves.
Old 12-16-2005, 09:06 AM
OK, I was bored so maybe you'll be lucky.
Try Pulling the plug for the Internal tempature sensor pin 1/4 (red wire)
If not, remove batt + connection
Try removing lifting Roof Relay G21, (just pull out the relay to test and don't use the roof while you check that. pin 1/9 (red wire)
Heater/AC red wire is the last major group I could find
However I did notice a connection to DME Pin4 (red/black) but I doubt that's it.
That should get ya started.
Old 12-16-2005, 04:08 PM
