Fuse #29 keeps blowing causing climate control inop
I keep blowing fuse #29 which in turn causes the climate control unit to go inop. Any ideas on where to start?
That Guy
Does the fuse blow imeditatley after you replace it?
You will need to start going through everything that fuse #29 is related to in order to see where your short is. Is your car an early or late model?
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
It takes a little while before it blows (it will function normally for a little while). Does anyone know what that fuse serves.
OK, I was bored so maybe you'll be lucky.
Try Pulling the plug for the Internal tempature sensor pin 1/4 (red wire) If not, remove batt + connection Try removing lifting Roof Relay G21, (just pull out the relay to test and don't use the roof while you check that. pin 1/9 (red wire) Heater/AC red wire is the last major group I could find However I did notice a connection to DME Pin4 (red/black) but I doubt that's it. That should get ya started.
