sts sts is offline
Question 944 pulsating acceleration
My 944 (normally aspirated, 1984) is running OK but not great. When accelerating it seems to lose some power every second or two for just a split second, e.g. "pusating power". I suspect either a timing belt or injector system, but wonder if anyone else has ideas.
Things I have checked and are OK:
Air and fuel filters new
Spark plugs and distributor cap new, all firing
Coil resistances correct
Various sensors in the fuel and ignition system seem nominal
All injectors working (not necessarily perfectly)
Old 01-02-2006, 06:24 PM
SoCal Driver's Avatar
Don't think it's the timing belt. Could be a vacuum leak in the small tubing to the fuel regulator/damper or somewhere in the intake system.
Back to the timing belt; when is the last time it was replaced? These are good for about three years or 30,000 miles.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-02-2006, 06:37 PM
winter-hater club member
nynor's Avatar
vacuum leak.
socal: you are the man.
check your belts!!! a kitten will thank you!
"COOL PRIUS!" - Nobody Ever
Old 01-02-2006, 08:55 PM
FSAEracer03's Avatar
Send a message via AIM to FSAEracer03
1) Check all the vac lines with a quick visual inspection.
2) Check the injector electrical connections.
3) Check out your AFM connections (electrical contact points and rubber connections - namely the outlet side), especially concerning the intake bellows. With the engine running, knead the intake bellows a little bit, bending it in different shapes and such. If that effects the idle, replace it.
4) Do a quick vacuum leakdown by spraying Carb Cleaner around various vac connections and lines as the motor runs. If that changes the idle whatsoever, replace that line.
Kevin Reagan
1987 Guards Red 951 (Lorelei-- the 18psi temptress)
247whp/299wtq @16psi ...312wtq at 18psi, mmmm, torque!
Old 01-02-2006, 11:56 PM
BananaClip's Avatar
Send a message via Yahoo to BananaClip
I had this exact problem back when I was fighting with the check valve that goes to the hoses on the damper and regulator.
keep the dream alive!
1988 944 NA (purple)
Old 01-03-2006, 12:13 AM
Gee, I would have included the TPS...Bruce
87 951 (All stock commuter)
87 951 (Saturday night Special)
77 911S (token tail dragger)
83 928S (engine back in from tear down, interior gutted)
....Grasshoppah
Old 01-03-2006, 08:24 PM
TPS will give problems when you let off the throttle and the engine comes down to an idle.
I'm also thinking O2 sensor.
Old 01-03-2006, 08:44 PM
