How to remove accelerator pedal?
Any of you Pelicans know how to remove the accelerator pedal so I can remove the carpet? Not that I don't know how to do it myself I just thought I'd see if anyone else out there knew as much as I do...
'73.5 911T
'87 944S
'78 928
Old 01-10-2006, 01:44 PM
Cars & Coffee Killer
legion's Avatar
You say first, then I'll tell you if you are right.
5 liters of VVT fury now
-Chris
Old 01-10-2006, 01:55 PM
strange......
Bob S. former owner of a 1984 silver 944
Old 01-10-2006, 03:34 PM
SoCal Driver's Avatar
Learn to use your resources.
http://www.pelicanparts.com/944/944_parts/944_83-85/Pic55.jpg
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-10-2006, 03:47 PM
livewirevoodoo's Avatar
Looks to me like everything is held together by spring #18....
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 01-10-2006, 03:51 PM
Ya! Chure Ting!
Remove keeper #10. Twist pedal off of rod. Pull pedal back and take off the two nuts at the bottom.
Old 01-10-2006, 04:19 PM
Yeah, I tried using those resources but unsuccesfully. I was trying to access the nuts at the bottom. But now that you point out 10 it makes sense to me now.
Thanks SoCal!
'73.5 911T
'87 944S
'78 928
Old 01-10-2006, 04:36 PM
Would be nice to have a item number listing along with the image.
Old 01-10-2006, 06:59 PM
Kind of like this:
1 944 423 033 00 accelerator control /LL 1
3 944 423 071 03 accelerator cable /LL 1
4 944 423 973 02 cable /LL 1
5 N 012 323 1 circlip 1
6 827 723 511 A accelerator pedal 1
7 900 076 010 02 hexagon nut M 6 2
8 803 817 121 washer 2
9 477 721 543 bearing sleeve 2
10 N 012 436 2 lock washer 3
11 900 025 038 40 washer 2
12 999 703 183 40 buffer 1
13 477 723 601 nipple 1
14 477 723 611 nipple 1
15 311 713 269 A sealing sleeve 1
16 477 723 563 C tension spring 1
17 944 423 141 00 support 1
18 944 423 833 00 spring 1
19 999 512 350 02 hose clamp 1
20 477 723 567 support 1
21 477 971 881 A retaining bracket 1
22 477 971 851 cable clip 1
23 999 511 116 02 clamp X
24 E 999 591 573 40 hose holder 3
25 999 591 572 40 hose holder 3
26 944 423 731 00 adjusting screw 1
Old 01-10-2006, 07:15 PM
Politically Incorrect
onZedge's Avatar
Holy crap Hugh. All that for a Porsche accelerator pedal !!!
Of course - I did not see the diagram, but I guess a picture is worth (at least in this case) 43 words and a whole bunch of numbers !!)
LOL
Edek
'87 924S
'91 535i
Old 01-10-2006, 07:51 PM
The retards at Porsche thought they could lock the PDF file so no one could capture the text. Had to crack it so I could cut and paste.
Old 01-10-2006, 10:17 PM
patrat
Guest
Posts: n/a
really? I have never had trouble with the PDF text.
Old 01-10-2006, 10:28 PM
Which reader version are you using?
Old 01-10-2006, 10:29 PM
I have the same problem what did you do to crak it
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 01-10-2006, 11:35 PM
http://www.verypdf.com/pwdremover/index.htm
Did this not necessarily for the text but so I could export the images with out doing a screen capture.
Old 01-11-2006, 08:10 AM
I'm about to lose my freakin' mind trying to get the keeper off. Any tips?
'84 944 currently converting interior to black (among other things)
Old 10-02-2011, 10:43 AM
