billyboy's Avatar
front end alignment
My son installed new front shock inserts and lowering springs on his 944. For the front alignment, can any good alignment shop handle this or does it need to go to a Porsche specific shop? thanks
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler...
"The sea merely lies in wait for the innocent but it stalks the unwary."
Old 01-14-2006, 02:18 PM
SoCal Driver's Avatar
Any shop should be able to do it. Basically the same as the VW golfs. There is a trick with centering the rack. There is a hole with a plastic plug. Taking the plug out you will see that a bolt can be screwed into it. Bolt needs to have a point that fits into the dimple in the rack. This centers the rack for getting the toe in correct as well as the steering wheel alignment.
The only problem you might run into is clearence on the alignment rack.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-14-2006, 05:19 PM
Well i hope you get a good deal, Maybe they just saw me comming but I god quoted from " good guys " 150$ to align the front and 250$ to align the back b/c it takes a lil longer on " you're car "
I'm thinking that's way to much, What have you guys paid for alignments, what's reasonable?
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 01-15-2006, 11:53 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
I paid around 380 for a full 4 wheel. But that was on short notice and at one of the best race shops around.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 01-16-2006, 06:11 AM
Virginia Rocks!
VaSteve's Avatar
I'm planning on taking mine to the Porsche shop. They quoted me $282.
I have receipts from the PO that had it done for less the $100 somewhere in CA...a shop advertised in the local PCA mag.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 01-16-2006, 06:31 AM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
when i had mine it was $200 sumthin... but i had coilovers
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 01-16-2006, 06:40 AM
rudidelange's Avatar
A full 4 wheel alignment would cost approx 30$ U.S in my town, but then again a good 944 will cost 10k - 12k$ U.S.
1983 944 RHD Original. Uses all my spare cash!
1947 Morris Sold
1972 Benz Sold
1975 Benz Sold
1976 Benz Sold
1977 Benz Sold
Old 01-16-2006, 07:05 AM
Take it to Wal-Mark. They outsource it to China.
Old 01-16-2006, 08:03 AM
That Guy
Techno Duck's Avatar
I paid $100 to get the front end done when i switched to coil overs. The back, the guy could not figure out how to do. This was at your local mom and pop type place in town. I needed an allignment done quickly so i didnt really mind.
I was recently quoted $175 plus tax by a semi-local Porsche specialty shop for a four wheel allignment and also lowering the rear using the camber eccentrics.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-16-2006, 08:05 AM
If the alignment shop will do a VW Golf for $50 they should be able to do your 944 for $50. Same setup.
Old 01-16-2006, 09:04 AM
I went to a local shop, the alignment tech new the 944 very well. $50.00 for the front end, something is bent on the pass/side rear. Otherwise I coulda got a 4 wheel for $90.00. This guy knew his stuff told my son to bring it back once the rear is fixed. He'd give him a deal.
Old 01-16-2006, 06:32 PM
