Titanium lug nuts?
Hi i was removing my fuch wheels to get the numbers off the back
and as i was removing the lug nuts i got one off and i started looking around on the ground for it because i though id dropped it it was so very light i didint feel anything. so after admiring these lug nut i want to know more so i took one inside and started polishing it to see if it was aluminum but all that would come out was a blueish bronze luster. not aluminum, not steel, infact the material looks just like the titanium crank spindle my bmx bike has. now say these are titanium. are these factory? is there an aftermarket manafacter for these? what did they cost new? if they are not titanium and are aluminum then once again are they factory? do all 1985.5 euro 944s have them? if aftermarket who makes them, and who thought aluminum was a good substitute for steel now this was the first time i have ever taken my wheels off this car. ive only had it for about two months so i really dont know alot about it but i do know materials and these are not a ductile steel or brass. but are alloy nuts.
71' 911T Targa, current toy. 86.5 928s traded for new 911 71 911 Targa w/ gas burners, PMO's, *sold* Lamborghini diablo replica w/ 350 V8 85.5' 944 n/a euro ( gave to dad ) 87 fiero cp. candy blue, chrome 16's 90' DSM 24psi. 18G fmic, 82' benz 300sd turbo, intercooled. 73' Karmann Ghia cab. sold 04' Standard 250s ox, euro bb 28/10 gearing, odyssey, profile, 29lbs, check out www.vintagevwcars.com wanted: 914, 944, 928 project |
Will work for parts
They are factory and I belive that they are an aluminum alloy. Crazy huh? Its fun to see peoples faces when you hand them a lugnut and they feel how light it is. They are not cheep to replace however. I got some for a buck a piece and felt good about it. I think the color is the coating/tyoe of alloy. I have never looked into what kind of composition they have exactly, someone might know.
'88 944 240,100 miles -race car '05 Boxster 110,000 - Daily Driver '74 911 Targa - long term project |
well if they are aluminum than they must be at lease a 7075 grade
or higher. i cant see someone making them out of 6061 i cant hardly see someone making them out of any type of aluminum when someones life is relying on a soft metal like aluminum. are you sure they are not Titanium? you would think DR. Porsche would have been woried about these stripping out. but titanium would have stronger treads then agian aluminum is very easy to machine so maybe porsche's idea was not so bad
Grind on one and tell us what color the sparks are.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
way. good idea! titanum does spark much more than aluminum not sure what color to expect but ill tell you when i get back in to repost. ok i going out to see right now. (note my car is nothing special and a little scrach on a nut will hardly be noticed. BRB
ok here the news. i took one off and grinded a spot ( backside least visible) and i think its just aluminum. since there were no sparks at all.
and titanium sparks about like flint so the verdict is they are aluminum not Ti now are these factory?
Probably.
I always assumed mine were aluminum because the edges are all nicked up.
keep the dream alive! 1988 944 NA (purple) |
to me it just dont make much sence to use aluminum for lug nuts
but im also the same buy who could not make sence of my girlfriend having me buy her four of the same shirt. oh well
Yes, those were stock on my 86 when I bought it new. When I first took my wheel off, I thought they were plastic they were so light....and I said the same thing you did....my life is riding on these lug nuts! I still cringe when I take my car in for new tires and those guys put those impact wrenches on them. I make sure I go talk to the guy working on my car and let him know how much each one of them costs in case he decides he wants to strip one using that air wrench. Works pretty well, they never have put them back on with an air wrench after I tell them how much each one costs.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
now if i could just get the right key for the locking nut on each wheel
Well, glad to see I'm not the only one with this concern. How do you POLITELY chew someone out?
What should I tourqe them down to?
If it has wheels or tit's it'll give out problems. Early 85 944 94 Katana 750 924 Parts Car |
i usually hear between 90-96 ft-lbs.
and fierochris, for what its worth, just because aluminum is soft, doenst mean it isnt strong. look at all the frames, and engine cradles now. aluminum.
Non Compos Mentis
Yes, the factory lug nuts are an aluminum alloy, and should be torqued to 94-95 ft/lbs.
When I have tires mounted I throw the wheels in the back of my truck and leave the car sitting on jackstands in the garage at home. That way I torque them myself and don't worry about a doofus with an air gun. |
but aluminum threads and high torking and retorking are not a good mix.
Just like pastic cars melt when they catch on fire?
Sorry I couldn't help it. My best friend is obssed with his Fiero. All of his.
Ornery Bastard
(Britwrench is going to kill me for letting Firestone mount my tires...)
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
Why, they mounted mine? Well Bridgestone/Firestone did and they're awesome tires.
Ornery Bastard
