meister member
speedracing944's Avatar
got our new motor for the 'S' today :)
I took the truck and picked up our new motor for the 'S'. When put side by side with the stock motor I was amazed at how compact the LT-1 is. The v-8 is a 1993 Corvette LT-1 with 4 bolt mains, 300hp, 330 ft/lbs of torque.
Here is where I am at with sanding the engine bay. Things are starting to get uncrispified.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 01-08-2006, 05:35 PM
winter-hater club member
nynor's Avatar
very nice, keep us posted.
"COOL PRIUS!" - Nobody Ever
Old 01-08-2006, 06:18 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Any plans to do mods to the LT1 motor?
With your conversion, do you have to delete the brake booster?
I'd be really interested in swapping a LT1 into a 944 if you could keep the brake booster. Post-install pics are good too.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 01-08-2006, 06:30 PM
Burn the fire.
Brando's Avatar
Transmission go boom?
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 01-08-2006, 09:29 PM
meister member
I am not going to do any mods to the motor yet. I want to break it in and work out all the bugs.
There are a couple of different options forthe brakes... There is a hydrobooster on the market which I heard from some guys running it that it is quite good. Some guys are running "big reads" with manual brake set up and they are happy with that as well.
Speedy
Old 01-09-2006, 04:59 AM
Zero10's Avatar
Damn this thread.... this has got me thinking again....
Used LS-1's and LT-1's are pretty cheap these days. The conversion kit is pretty expensive, but not _THAT_ bad. Rather than spending $10k building a new 951 motor to make a reliable 400HP, why not just bite the bullet, and use a vette motor?... gah.
Did you buy a conversion kit, and if so, do you have pictures of it?
Buy my parts!
Old 01-09-2006, 08:57 AM
meister member
The 'S' tranny has the same gearing as the turbo tranny with the exception of the final drive ratio. I will have a lower top speed but I think it will place less strain on items. I don't plan on doing stop light drags but more of 3rd and 4th gear pulls to show my EVO buddy who's the man. Actually this car is being built for my wife who will not be hard on it at all. I am sure she will lend me the keys once in a while.
Zero10... I have not bought a "kit" yet. I need to collect the computer, wiring harness and accesories. I wanted to make as many parts as possible and then buy the rest. You can see pics of the conversion parts at
http://www.renegadehybrids.com
or if you have any swap questions you can go to
http://www.porschehybrids.com
There is a gallery with pictures of guys conversions. In there you can see the brake boosters they are running and some examples of the cars. Some areas even have movies
Speedy
Old 01-09-2006, 04:02 PM
Wow, 9 posts and no flames yet. Amazing!! Robot and I are doing a little home work on a good manual brake setup. Shoot me a pm and I'll give you my home email if you like.
Old 01-09-2006, 04:24 PM
meister member
I don't think I have ever been flamed. I respect everybody on the board so it must be coming around full circle
Speedy
Old 01-09-2006, 04:36 PM
Wolf1's Avatar
Are you getting the harness and computer from the 93??
I would look for a harness, computer, and distributor from a 95 if possible. Several advantages to the 95 stuff over the 94 and older equipment.
Not too mention, I probably have most of the 95 stuff...
FWIW......if you do use the 93 distributor, check into the corrosion issues with it, and atleast replace the cap and rotor. Its real easy now....... and a real ***** later.
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 01-09-2006, 04:55 PM
meister member
Do tell about "I probably have most of the 95 stuff..."
I have a couple of different sources for these things...mostly fbody.com and corvetteforums.com but if I could get what I need from a fellow Pelican...
Speedy
Old 01-09-2006, 06:59 PM
Zero10's Avatar
Are you sure on the specs of that LT-1 motor? I thought they all produced 200-something horsepower.
You got me thinking on this swap, and now I'm so tempted to drop a nice LS-2 in my 951.... gah! The mod bug has bitten me again, I might as well go burn all my money now.
Seriously though. This is a most interesting conversion that has caught my attention. You can be sure I am following closely
Buy my parts!
Old 01-09-2006, 07:30 PM
meister member
the Camaro and Firebird are 275 HP. The Vette is 300 HP. I will have to use the Camaro/ Firebird accesory package though because of clearence issues.
Speedy
Old 01-09-2006, 08:01 PM
Zero, my friend, check out some LT1/LT4 boards. It is late, I'll dig up some links 2marow. about 400hp is no prob. right off the top of my head, check the Edelbrock cam n top end. $ n area under the curve are hard to beat. LSx even better, 1000 more rpm n 90# lighter but 2g mo$
Choose your poison, welcome to the dark side.
Old 01-09-2006, 10:51 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
youll have to be more specific that just the edelbrock cam. there is more than one grind for these motors.
now this is what id love to throw in a '44.... if i ever won the lottery
http://www.gmpartsdirect.com/results.cfm?singlepart=1&partnumber=LS7
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 01-09-2006, 10:57 PM
The parts I was referring to was the Edelbrock RPM Performer kit that included heads, intake and cam. I cant find it now but this is the GM equivalent. Both are priced well under 2500$ Sorry my previous post was written late at night (well...actually after monday night poker with extensive libations).
GM Performance Parts LT4 Conversion KitsTurn your LT1 into the engine it wants to be.
Have an LT1, but want an LT4? GM Performance Parts has what you need. These LT1-to-LT4 conversion kits bring the most out of your factory LT1 engine. The kits include LT4 cylinder heads with valves and springs, a red aluminum LT4 intake manifold, GM Performance Parts' hot cam with 1.6:1 ratio Bow Tie roller rockers, and all necessary gaskets. The result of all of these mods is 425+ proven horsepower! (copyed from the Summit catolog)
Old 01-10-2006, 06:52 AM
Zero10's Avatar
So, I should be hunting for a LS4?...
A LS2 would be nice. 6.0L is better than 5.7L
I worry about intake manifold clearance however.
The 7.0L is probably a big block, and won't fit in our engine bay.
What would be really nice is to build a LS1 or LS2 to ~400HP, and bring the redline up to a safe 6500RPM. That way it would beat the performance of my 951 motor, but also match the top speed.
It sounds like 400HP is a nice safe reliable HP level for a LS1 or LS2, and I won't really be pushing it to it's limit (I would rather have longevity than another 20HP. This car will still be a daily driver).
Now I need to get on the corvette boards and find a used LS1, LS2, LS4, or LS6.....
I wonder if any other LS series motors would fit?
Damn this thread! I can smell my wallet burning already.
Buy my parts!
Old 01-10-2006, 11:28 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
These threads come around and I start to get giddy again This morning I had the random thought of getting a part-time job, in addition to my full-time one and being a full-time student, just for more spare $$ for parts.
I want a shortish stroke LT1, with a medium amount of power. I'd like it to match the power curve of my na engine as close as possible. Of course, I know diddly about V8 engines or cam and crank combos.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 01-10-2006, 11:45 AM
A LS4 would be very hard to find. But conversions are just a phone call and a VISA number away. They clear the stock hood just fine. Preditor on the 560 board runs this setup. Lotsa converted cars are in the gallery.
http://www.560sec.com/bulletinboard/index.php
Old 01-10-2006, 11:56 AM
Zero10's Avatar
Okay, so LS4 sounds too expensive... LS1/6 or LS2 it is
Sounds like the LS1 is ideal, since it's a good bit cheaper and more common than a LS2. Also LS1's are available from lots of engine suppliers as retro-fits to old hotrods, so you don't need to try and fool the ECU's from a new vette into working, since they come with their own....
Damn.
Buy my parts!
Old 01-10-2006, 12:30 PM
