Angry shift boot help
tried to put my new shift boot on today , what a pain in the A$$. I tried to heat up the boot with a heat gun, I tried to put tire mounting lube on the inside of the boot and the shift knob, I couldn't get it either way and I wound up tearing a couple of the stitches in the seam, I worked at it for a good hour or so. Am I doing something wrong or what?
1992 freightliner
1994 freightliner
1970 dodge challenger r/t se
1994 ford f-150
1984 porsche 944
1991 corvette z07
hopefully a 2008 dodge challenger
Old 02-21-2006, 05:07 PM
Virginia Rocks!
VaSteve's Avatar
Sounds like mine. I put it in the microwave to heat it up. Slid it in real slow and grabbed the top edge with a needle nose pliers to pull it the rest of the way. Took like an hour of working it to get it on.
I used a little of that noxious yellow 3M weatherstripping glue. Held like magic within seconds while I jammed it under the cap.
I would've never done that job knowing what I know now.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 02-21-2006, 05:25 PM
I tell you what, that was like trying to put a condom on an elephant, it just isn't going to work. I too used a plier to try and pull it up. finally I just said the hell with it, slid the boot down, put a rubberband around it and put it back together. I may try it again someday, but not anytime soon.
1992 freightliner
1994 freightliner
1994 ford f-150
1984 porsche 944
1991 corvette z07
Old 02-21-2006, 05:35 PM
Just thinking out loud
mattdavis11's Avatar
Did you guys turn the boot inside out first? What brand of boot did you buy? Heard that some boots are a tighter fit than others, IIRC, Alga was the best fit. I need to do this soon.
91 FJ80
84 Ram Charger (now gone)
Old 02-22-2006, 08:19 AM
I tried to get it on again last night and I finally succeded. I got the wheelskins boot from zims
1992 freightliner
1994 freightliner
1994 ford f-150
1984 porsche 944
1991 corvette z07
Old 02-22-2006, 10:26 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
hmm. mine was a tight fit, but went on just fine. i guess these things just vary one car to the next.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 02-22-2006, 02:24 PM
