tried to put my new shift boot on today , what a pain in the A$$. I tried to heat up the boot with a heat gun, I tried to put tire mounting lube on the inside of the boot and the shift knob, I couldn't get it either way and I wound up tearing a couple of the stitches in the seam, I worked at it for a good hour or so. Am I doing something wrong or what?
1992 freightliner 1994 freightliner 1970 dodge challenger r/t se 1994 ford f-150 1984 porsche 944 1991 corvette z07 hopefully a 2008 dodge challenger |
Virginia Rocks!
Sounds like mine. I put it in the microwave to heat it up. Slid it in real slow and grabbed the top edge with a needle nose pliers to pull it the rest of the way. Took like an hour of working it to get it on.
I used a little of that noxious yellow 3M weatherstripping glue. Held like magic within seconds while I jammed it under the cap. I would've never done that job knowing what I know now.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
I tell you what, that was like trying to put a condom on an elephant, it just isn't going to work. I too used a plier to try and pull it up. finally I just said the hell with it, slid the boot down, put a rubberband around it and put it back together. I may try it again someday, but not anytime soon.
Just thinking out loud
Did you guys turn the boot inside out first? What brand of boot did you buy? Heard that some boots are a tighter fit than others, IIRC, Alga was the best fit. I need to do this soon.
83 944 91 FJ80 84 Ram Charger (now gone) |
I tried to get it on again last night and I finally succeded. I got the wheelskins boot from zims
Writer/Teacher
hmm. mine was a tight fit, but went on just fine. i guess these things just vary one car to the next.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
Thread Tools | |
Rate This Thread | |
