v944's Avatar
removing rear hub - help!!!
Hey guys I'm trying to remove rear hub to change studs for longer ones, and it wouldnt come off, if anybody has any ideas why - pleas let me know
v944
Old 03-10-2006, 09:36 PM
Let's go shooting.
Dark Skies's Avatar
Assuming you have removed the rear disc / handbrake drum ...
They can be pretty tight. Use a hub puller. Hook the puller's legs around the square section of the hub carrier.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 03-11-2006, 12:17 AM
Usually you can replace the studs without removing the hub, depending on the length. As we don't know what year your 944 is, there are two hub designs, 82-85/1 (steel trailing arms) and 85/2 - 95 (alu trailing arms)
The early ones you can get the hub out without damagiing and therfore having to replace the bearings. The later one, you will need to replace the bearing.
All the information is in the workshop manual, either the Haynes or factory.
Of course, you could just get the "bolt-on spacer" that both Porsche and several other companies make.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 03-11-2006, 05:38 AM
