The Chief's Avatar
Send a message via Yahoo to The Chief
Porsche Crest Backup light problem
When shifting in reverse, my backup lights will "blink" rather softly, and then go out. Fuse is good, as mirrors and turn signal indicators work.
(1) Could this be a bad ground? Ground location?
(2) Is the reverse switch located on the right (passenger) side of the tranny, above the half-shaft?
(3) Is there any adjustment for this switch, or is it a simple replacement?
Thanx, Pelicans!
1987 924S (Gretchen), Black on Black, phone dials, modifying for Autocross, daughter's car. (R.I.P - for now)
1978 928E, (Heidi), Minirva Blue, Op-Art & Cork Interior
1993 Mercedes 300DL Turbo (The Black Knight), Black on Black, wife's car.
Old 03-13-2006, 03:40 PM
AFJuvat's Avatar
1. Possible bad ground, but not likely - the ground is in the rear of the car, under the carpet, between the lights. - the other lights would blink too.
2. Yes, that is it, check for damaged wires.
3. No adjustment, just replacement.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-13-2006, 06:53 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
You could try electrical contact cleaner but it will probably only buy you a little time unless you want to keep cleaning the switch over and over. The best thing...just replace it.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-13-2006, 08:41 PM
The Chief's Avatar
Thanks, guys, will be pulling the switch in the morning
Old 03-13-2006, 09:36 PM
